Results 1 to 10 of 10
Thread: 1jz-Gte JZZ30 Wiring?
    Nov 2010
    Default 1jz-Gte JZZ30 Wiring?
    Ok guys as some know im putting a 1jz out of a jzz30 into a ra28 celica. My question is do i have to use all those secondary ECUs that are part of the jzz30's loom.
    At last count there was about 40 of them!! And frankly i won't be running airbags or 'suspension adjustment' etc etc... Will this work if i don't connect them up? Or will the engine go into a limp mode and be ridden by a million error codes?
    Cheers Guys
    May 2007
    Default Re: 1jz-Gte JZZ30 Wiring?
    should be able to get it to work without them... if you connect the engine light it will probably stay on though...
    might need to ground a wire on the ecu to get it to rev cleanly though
    SPARCO|TEIN|SUPERPRO|SELBYS SWAY BARS|PERFORMANCE PARTS AND APPAREL LIKE US ON FACEBOOK!
    Nov 2010
    could i just put a resistor in its place? like one does with airbags to fool ecu
    Nov 2011
    U dont have to ground a wire to make it rev
    Just wire it right and your done
    Just use engine ecu and fuel pump ecu if u want no codes
    Nov 2010
    hmm fuel pump ecu, where was that located roughly? please don't say in the boot
    Nov 2011
    yes in the boot but do a search theres other ways around it
    Nov 2010
    cheers mate
    The engine ECU will be fine without the ABS, TEMS etc wired up.
    Wiring and details of each of the engine & engine loom pins on my wiki
    http://wilbo666.pbworks.com/w/page/4...20COR%20Wiring
    Details on how to trigger a fuel pump relay / COR (Circuit Opening Relay) without the Fuel Pump ECU (which is located inside the car, behind the rear passenger trim as shown in the below image - 89570A) also on my wiki
    http://www.toyodiy.com/parts/p_J_199...CPVZ_8404.html
    Wilbo's JZA80
    Wilbo's JZZ12
    May 2007
    Quote Originally Posted by dumbass View Post
    i have 1st hand witnessed having to do this... otherwise it hit a rev limiter at about 4500rpm...
    by wiring it right i left it all plugged in as factory and gave the appropriate pins ignition power as soon as the NSW wire was grounded it revved fine...
    but that being said thers more than one way to skin a cat and my wiring elsewhere might have caused the need for this...
    Nov 2011
    maybe some models u need to ground it but ive never had to do it in over 100 1j/2j wiring jobs
    its mainly due to nsw and sta being wired wrong when u go manual and ivbe also seen people wire it
    wrong in auto form as one wire gets feedback thru the starter motor solenoid wire which can cause issues
  1. JZZ30 a340e speed sensor wiring into MX83
    By Cressii in forum Tech and Conversions
    Last Post: 17-03-2012, 01:38 AM
  2. jzz30/jzx90 wiring info.
    By celupra in forum Tech and Conversions
    Last Post: 09-12-2011, 02:44 AM
  3. jzx90/jzz30 1jz-gte wiring diagram
    By Steve-AE86 in forum Tech and Conversions
    Last Post: 20-05-2011, 07:20 PM
  4. JZZ30 A340 solenoid wiring diagram
    By midnight_purple_GA70 in forum Tech and Conversions
    Last Post: 31-05-2010, 06:17 PM
  5. 1jzgte into 88hilux, jzz30 wiring help????
    By hu5tln in forum Tech and Conversions
    Last Post: 28-01-2009, 08:13 PM
