You might have to do what I did and pull the gearbox to check the flywheel size - it's a pain but at least you know you'll get the right clutch
hey guys this is a bit of a particular Question, but does anyone know exact measuremnts of a st165 flywheel ? length or wat not,
Or heres a better question i currently have a st165 gt4 fly wheel on my car and i am buying and putting on a heavy duty exeedy clutch that is made for my st184 s54 gearbox, can anyone tell me straight up that the flywheel and clutch will match up ?
can take measurements of 185 flywheel, but they are bigger and different sizes.im pretty sure that a 184 clutch disc will be bigger than the 165 flywheel, as the 184(5s) used the same size flywheel as a 185 (same part number) im sure you;re gonna need a custom unit here Jorrs. Sorry to be the bvearer of bad news buddy
shit hey.. ive already ordered the clutch and its waiting for me to buy.. wat reckon i should do ??
see if they can make up a HD clutch disc to suit 165 flywhel?The hub will ned to be the same as the 184 (s53/54 gbox) but the clutch disc diameter will not be.i recommend getting an exact measurement on the 165 flywheel. oh, i think i might have a 162 flywheel i can measure up. ill check for you - they might be the same size
i think the pressure plate is 225 mm or 25 cm cant member im pretty scattewred atm
yeh its 225mm so does anyone no if this will fit with my flywheel ?
