Results 1 to 3 of 3
Thread: help with fuel injector impedance resistor
    Default help with fuel injector impedance resistor
    hello,
    i am wanting to upgrade my stock 2jzgte 440cc injectors withthe septic 550s and know that i need a resistor to adjust for different resistor and have a few questions:
    finding the stock resistor pack that is unmolested is a bit hard BUT IF I DO; how to wire it in? is there a plug somewhere?
    i have heard that you can use a 7mge resistor pack which i have obtained but this seems to be just one big resistor (as opposed to the 6 resistors that people make from jaycar) how to wire this in also?
    do i have to install this in the engine bay or can i splice it into the ecu from inside the car?
    has anyone here done this?
    info would be great i will pay you big rep.
    Melbourne Victoria
    Default Re: help with fuel injector impedance resistor
    ok whats the ohms on the std 2jz injectors and what are the septic ohm rate 1st
    Quote Originally Posted by PlacentaJuan View Post
    I've seen resistor packs with one supply and 6 wires out. Also one supply and two wires out. Widen your search to 5M and 6MGE engines and you'll find one that suits.
    note, if the resistor pack as 2 wires out, then each output feeds 12+ supply to 3 injectors, if the pack as 3 wires out then each output feeds 2 injectors (and so on). This is obviously for a 6 cyl.
    done in the engine bay - it's wired in between the 12+ supply to the injectors and the injectors themselves.
  1. Resistor pack for low impedance injectors on 1JZ?
    By Jabtronic in forum Tech and Conversions
    Last Post: 06-10-2011, 11:31 PM
  2. Raising injector impedance.
    Last Post: 10-02-2010, 08:22 PM
