I have it on good authority that the C series engine is a diesel version of the S series. So a bellhousing designed to fit a 2C-T will fit a 3S-FE.
You should be ok without the speed sensor (though 93 is getting a little late), on earlier ECUs the engine runs fine with it disconnected. And using a manual, not an auto box will eliminate the chance of this causing shifting problems.
Good luck.
Hen
