can you get a pic of the other side of that bolt on the fork? on the other celica setup, it looks like it clamps the fork onto the shaft instead of going through it. i'd say there's a notch in the shaft so that the fork can't fall off. if i'm correct so far, you need to take the bolt out(screw the nut just onto the end two turns, so you don't stuff the bolt thread) and give it a light tap. it should loosen and pull out, if it doesn't move, then discontinue with the hammering
