www.mrpltd.co.nz
Fortune Auto|Wilwood|Quartermaster|Fidanza|ARP|TRE|MOTUL|M aster Power|RC Injectors|Aeromotive|Enkei|Rota Wheels|Work Lug Nuts
We are the Sole Distributor for Fortune Automotive for the NZ & Australia regions.
Why buy Fortune Auto Coilovers?
- Fortune Auto Coilovers are the best coilover you can buy in its price range.
- Fortune Auto valve and assemble their coilovers at their factory in the USA.
- Fortune Auto are suspension specialists, this is their full time job! The coilovers are not generic mass produced; they are made to customer’s orders and their needs.
- Custom valving is done to suit your car and your needs, whether it is for comfort, sport, or race applications.
- All shocks are dyno tested before being sent to you, they also provide you with the Dyno graph sheet!
- All Fortune coilovers are rebuildable back at their USA facility
- They use a specially designed Digressive 50mm shock pistons (case diameter 57mm!), all other coilovers on the market use 44mm pistons! with 50mm cases.
- Comparable performance to KW, JIC etc.
Fortune Auto 500 Series Coilover
Fortune Auto 500 Series Vs Competitor - Check out the size difference! Another 7mm larger in diameter
DIGRESSIVE* All Fortune Auto shocks use a superior DIGRESSIVE piston. This technology allows for stiff, progressive (linear) damping at low stroke speeds. This helps to control vehicle body motion like roll, dive and squat. However at fast stroke speeds (i.e. high speed bumps) the suspension is kept supple in response to bumps and irregularities in the road.
Dyno tested***
Mono-tube shock design
IP synthetic 5w or 10w shock oil (prevents cavitation and promotes superior heat dissipation)
Stainless steel body / piston
30-way adjustable dampers
Pillowball mounts
Forged aluminum locking collars
Cold Forged aluminium bottom mounts
Dust boots on all pistons
Digressive* 50mm piston-57mm piston housing (beyond the industry standard of 44-47mm)
Anodized aluminum camber plates** on front upper-mounts
Fully anodized body
1 year Manufacturer's Warranty
Height adjustment independent of preload
ISO 9002 certification
***Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned us our ISO certification.
Furthermore we incorporate features only found on our coilovers such as Seamless stainless steel monotubes, Forged lower mounts & proprietary nitrogen gas chambers
Custom Spec Options
1. Your choice of drag, drift, street or track spec valving
2. Your choice of custom spring rates from 6k to 13k
3. **Adjustable camber plates included on MOST vehicle front coilover applications with Macpherson Strut suspension systems
RRP$1650AUD incl Shipping
Introductory special-
$1400AUD incl Shipping
Now 9AGTE 410kw atw
How Fortune Auto Valve their shocks & R&D that goes into them - Shock Tech - Fortune Auto USA
Click Here -
Click Here -
Now 9AGTE 410kw atw
