Results 1 to 15 of 20
Thread: Toyota Wilwood BIG Brake Kits
    Jul 2008
    Auckland
    Default Toyota Wilwood BIG Brake Kits
    FortuneAuto|Wilwood|Quartermaster|Fidanza|ARP|TRE| MOTUL|MasterPower|RC Injectors|Aeromotive|STD Suspension|Enkei|Rota Wheels|Work Lug Nuts
    Hi Guys,
    We have been providing popular brake kit upgrades for a while now.
    Can custom fit these Wilwood brake calipers onto anything! just ask!
    Any caliper, nearly any car. We custom make these in house.
    AE86, Supras, Escort, Honda, Primera etc
    Wilwood Brake kits (Calipers, Rotors, Adapter brackets, hardware etc)
    - 4 piston, 6 piston, 2-piece rotors, brake bias valves
    - Custom adapter brackets to fit calipers to any model car.
    Massive gain in stopping power!, never have to worry about brake fade again. Pad replacement is fairly cheap!! starting from $100nzd for fast street up to $180nzd for race pads. Direct bolt up, no need to change master cylinders or Bias valves.
    Corolla AE86 Wilwood Dynapro Kit 278mmx25mm suit 85% of 15" wheels - $1360NZD shipped! (approx $1120AUD)
    - Dynapro 4 piston caliper
    - Wilwood BP-10 Smart pad for Fast street and odd track day use
    - Brembo 280x25mm discs redrilled (We can also do 265mm kits to fit 14" wheels and larger discs to suit 16-17" wheels)
    - Custom 2-piece steel powder coated adapter brackets, this also means its easy if you want to change to smaller or larger discs in the future. You would only need to purchase from us half the adapter bracket to convert which is very cost effective.
    - Ours discs are all 25mm thick, other kits on the market use 22-23mm thick discs which in our opinion is not thick enough for hard race conditions.
    - Also of other kits use the very old "Dynalite" caliper which is prone to un even pad wear and squeely pads.
    Additional Options
    1. Braided brake lines +$140NZD (Might be better to get this part done in Aus)
    2. Custom 2 piece alloy hat setup +$240NZD
    Corolla 280mm (AE82/92/101/111) 15"+ Wheels - $1380nzd incl delivery to anywhere is AUS
    MacPherson Strut or Superstrut 280mm Dynapro 4 Piston full bolt on kit with braided brake lines - This is our most popular kit PM us for more details!
    Corolla 300mm+ (AE82/92/101/111) 16"+ wheels - $1400nzd incl delivery to anywhere is AUS
    McPherson Strut & Superstrut 300-315mm (Toyota Celica GT4 OEM Heavy Duty Discs) Superlite 4 Piston full bolt on kit with braided brake lines
    Celica ST202 300mm+ - $1400nzd incl delivery to anywhere is AUS
    McPherson Strut 300-315mm (Toyota Celica GT4 OEM Heavy Duty Discs) Superlite 4 Piston full bolt on kit with braided brake lines
    We can also do brand new Toyota OEM ST205 GT4 4 pots onto any of the above setups!! it does add a little extra cost around $200-300.
    Now 9AGTE 410kw atw
    Default Re: Toyota Wilwood BIG Brake Kits
    you dont have a hat drawing or setup to do a 2 piece kit for a ke70/te72/ae86 do you?
    currently working on fitting a set of ~300mm rotors under a 15" rim on my 2 door 1g ke70, was looking to use a CP5200 caliper, due to the much bigger pad area than the CP 5100, how does pad area on these wilwoods compare to the AP racing calipers?
    the 280mm kit your selling, is that the same caliper as the calipers being used by techno toy tuning in his big brake kits?
    Jul 2008
    Auckland
    Quote Originally Posted by love ke70 View Post
    We use the Dynapro calipers as seen in the pics above. The Dynalite which is used in the T3 kits are VERY OLD design which flex alot and has uneven pad wear. Both calipers use the same pad surface area. We run these are many race cars with great results!
    We also use a 2 piece disc setup and a proper caliper bracket which bolts to the actual hub (replaces the dust shield which has the original mounting brackets).
    Just made a kit for a customer but didnt get time to snap pics, will ask him to do it for us so you can see our caliper brackets and 2 piece disc.
    We can do any kind of setup you want. If you want 355mm discs we can do that no worries . If you want us to fit your supplied calipers we can also do that.
    I can point out some flaws in the T3 kit for you:
    1. If you look at the brake discs used the venting for the discs is totally the wrong way around. Running brake ducts would not do anything on their kits as the air needs to enter from the wheel side, the discs they used are for Euro cars where the wheels suck the air into the centre. If they showed a pic of the discs around the other way you will see its solid there are no vents from the back side.
    We have tried these discs on the rear of an Escort race car and they over heated after 1 race!. Changed to a disc with the cooling vents the correct way then no more issues.
    Look at the pic closely:
    2. Uses the old Dynalite caliper
    3. Caliper brackets bolt to the stock mounting which IMO isnt that ridgid. Works but id prefer proper brackets which replaces the stock ones.
    Now 9AGTE 410kw atw
    Apr 2011
    Hi mate any chance you could do a kit for The front of a 2005+ hilux 2wd. With 6 pistons calipers and 355 dics??
    Cheers josh
    Apr 2011
    Cheers josh
    Jul 2008
    Auckland
    Quote Originally Posted by glide3 View Post
    Cheers josh
    We have listed Tacoma 05+.. think its the same vehicle?
    Can get the 355mm 6 piston kits. Which would be $1850NZD for a front kit.
    Now 9AGTE 410kw atw
    Hi Barry,
    i emailed you from your website but am not sure if it got through.
    My ep82 has 4 pot wilwoods on front (old superlite design i think) and has approx 255mm diameter discs. I believe it runs a small dogbone but havent actually checked. I'd like to run a larger disc somewhere in the vicinity of 280mm. Can you hook me up with discs and dogbones to suit? I imagine that wilwood havent changed their caliper mount measurements at all........
    Cheers mate,
    Stu
    EP82 Starlet GT - [URL="http://www.toymods.org.au/forums/forum-members-rides/71090-stus-ep82-starlet-gt.html"[/URL] SOLD
    EP82 Starlet GT V2.0 - http://www.toymods.org.au/forums/sho...98#post1514198 SOLD
    The IS400, GXE10 with 1UZ - http://www.toymods.org.au/forums/thr...8-StuC-s-IS400
    Jul 2008
    Auckland
    Quote Originally Posted by StuC View Post
    Hi Barry,
    Cheers mate,
    Stu
    I dont think a Superlite could fit on a disc that small...
    Id need a pic to see and make sure its that caliper.
    I can do discs and the adapter brackets for $420NZD
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Hi Barry,
    Cheers mate,
    Stu
    Now 9AGTE 410kw atw
    Oct 2012
    Just wanted to say thanks Bazda, the kit was of high quality, easy to put on and fitted like a glove. Also Barry was more than happy to help with my question's.
    This is all i have at the moment Barry, i'll get another shot up once i smash these lock nuts off.
    Jul 2008
    Auckland
    Not superlites. Superlites are massive!
    There will be a model number on them somewhere
    Now 9AGTE 410kw atw
    awesome, i'll have a hunt around with my mirror. Cheers Barry
    Jul 2008
    Auckland
    Quote Originally Posted by Ownage Input View Post
    Great to hear another happy customer
    Now 9AGTE 410kw atw
    May 2011
    any kits for a ST185?
    thank you
    1990 ST185 Running stock Gen 3 power, 216awhp at 15psi. 13.6 second down the quarter
