Results 16 to 20 of 20
Thread: Toyota Wilwood BIG Brake Kits
    Jul 2008
    Auckland
    Default Re: Toyota Wilwood BIG Brake Kits
    Quote Originally Posted by aus jd 2703 View Post
    any kits for a ST185?
    thank you
    Yes kits for ST185 available. Same prices.
    Now 9AGTE 410kw atw
    May 2011
    what calipers do you use? part number?
    what size rotor?
    thank you
    1990 ST185 Running stock Gen 3 power, 216awhp at 15psi. 13.6 second down the quarter
    Jul 2008
    Auckland
    what size rotor?
    thank you
    depends what size wheels your running.
    Typically we use the Superlite Forged caliper 4 piston (1.38" pistons). Mated to a disc size thats going to fit in your wheel.
    So anywhere from 300mm-330mm disc size. The thickness would be from 28mm-32mm thick discs. Normally we use 32mm thick.
    So cant give you an exact number until I get a bit more detail on your side...
    Now 9AGTE 410kw atw
    May 2011
    my appolagies.
    17 in wheels so looking for 330x32mm rotors
    how much exaclt will that be?
    thank you again
    Jul 2008
    Auckland
    my appolagies.
    thank you again
    Using OEM style rotors there isnt much available in 330mm.
    We would use a Skyline 324x30mm disc for this setup. Re-drilled to suit your stud pattern.
    And using the Superlite caliper we mentioned. I think the part number is 120-11130
    That kit would be $1250AUD delivered.
    Optional Extras: Slotted discs +$50AUD
    Wilwood 2-piece discs +$400AUD
    Now 9AGTE 410kw atw
