Results 1 to 3 of 3
Thread: Bumpsteer measurements
    Default Bumpsteer measurements
    When measuring bumpsteer are you supposed to have your suspension setup as you'd normally have it or do you reset it to 0 toe?
    I read somewhere that you are supposed to set it to zero toe but that doesn't seem right to me as the normal amount of toe would have an effect on the bumpsteer. Exactly how much effect this would have I don't know but as I am trying to measure my bumpsteer to make changes I want to get my measurements as correct as possible.
    Default Re: Bumpsteer measurements
    Logic would push me to say measure from your factory settings, eg that might be 1deg of toe at ride height. It certainly wouldn't hurt to measure both though and get the measurement at 0deg toe also. Just remember the toe in on suspension compression will be amplified the more toe there is at ride height.
    Bacause this is an exponential curve the difference between 1 and 0 toe at ride height will be the position of the curve, eg it gets shifted left the more ride height toe exists. As part of this, the point at where a certain degree of toe is reached is achieved alot faster the more toe you start with.
    I just found a few links that appear to have formulas for this already. Have a look;
    http://www.nissanroadracing.com/showthread.php?t=1445
    http://www.speed-wiz.com/graphs/steering-graph.htm
    http://www.speed-wiz.com/calculation...simulation.htm
    Thanks LeeRoy that confirms what I was thinking.
  1. 2S bellhousing pic or measurements?
    Last Post: 18-08-2009, 08:40 PM
  2. 3VZ block measurements?
    Last Post: 23-06-2006, 09:43 PM
  3. What are measurements for a 1JZ?
    By robski in forum Tech and Conversions
    Last Post: 01-04-2006, 03:44 PM
