Results 1 to 6 of 6
Thread: 1jzgte: power steering pump & a/c compressor.
    Jun 2011
    Thumbs up 1jzgte: power steering pump & a/c compressor.
    hows it?
    im new on here, first post- but anyway im chasin a few parts for my 1j into 180sx conversion.
    - a/c compressor + pulley.
    - power steering pump + pulley.
    - water pump pulley only ( already got a pump ).
    any and all info much appreciated.
    if anyone has these part #'s would be handy also.
    cheers!
    jay zee zee thir tee Carport Converter HAVABEER's Avatar
    Default Re: 1jzgte: power steering pump & a/c compressor.
    and thats why we have a parts wanted section. though you can't post in there till you get 30 rep, meaning you need to contribute to the site before you can use its services.
    Jun 2011
    no wurrys HAVABEER thanks for the heads up.
    May 2010
    Moscow
    r00t3R,
    you may use another p/s pump with custom welded mounts and at the same time get rid of a/c pump. That's the way I did.
    Jun 2011
    Thanks George'
    i thought about getting rid of the a/c but as the car will mostly be my daily driver i want to keep it and if i can get the origional pump and compressor i believe its only a matter of changing the nissan fittings to suit the toyota parts.( anyone feel free to correct me if im wrong or add some helpfull info ).
    cheers.
    May 2010
    Moscow
    You can have your a/c and p/s lines custom made at any good a/c place as well. So you can have for example a hose with Nissan fitting on one end and Toyota piece on the other.
  1. 1jzgte: power steering pump & a/c compressor.
    By r00t3R in forum Tech and Conversions
    Last Post: 18-06-2011, 04:55 PM
