Results 1 to 5 of 5
Thread: 1JZ into 74 corona mark 2?
    May 2011
    Default 1JZ into 74 corona mark 2?
    Hi all i was wondering if putting a 1JZ into my 74 corona mark 2 is a possible conversion?
    This is in terms of cost and if it will fit in general.
    Thanks for all help.
    i am a rollomatic Backyard Mechanic _gear2's Avatar
    New South Wales
    Default Re: 1JZ into 74 corona mark 2?
    You can and it has been done before - obviously any M series engine would be easier as there is no fiddling around with engine mounts etc. If i remember right if you get a vvti engine it doesn't foul the steering box.
    heres a build thread for you
    http://www.toymods.org.au/forums/sho...highlight=mx23
    i feel much better now that ive given up hope
    Brisbane
    vvti and convert to mid sump (if not mid sump already) and it should be a fairly straightforward affair.
    budget around $10k.
    May 2011
    Thanks for the help guys. Do you think a 1g-gte would be a better option?
    May 2006
    Have you got a welder and some basic skills? Someone I knew spent $12K walk in walk out for a 2JZ swap. If you can do most of the work yourself you can half that price.
