With respect to my particular situation the question has been partially answered. Will know for sure on the weekend when the alternative part is installed.
Hi Guys,
This post is a little long winded so bear with me!
I am rebuilding a 20 spline T50 transmission that I bought standalone so am not sure exactly what it came out of but am assuming that it was a Corolla.
It is being transplanted into a Mk2 Cortina but Sleeve, Transmission Hub No.3 is worn (probably due to jamming into reverse while moving forward) and so far I have been unsuccessful in sourcing a replacement. I have tried Australian toyota dealers, US dealers and Amayama in Japan with no success.
The part is a 33395-14010 which was replaced by 33395-14012.
I recently discovered that in the T50 fitted to the Corolla between August 79 & June 81 another part number (33395-14013) is listed which carried through into the later 22 Spline boxes. Does anyone know whether this would be compatible?
I have checked a few web sites and they are listing a 33395-26010 as a replacement for the 33395-14013.
Any help would be appreciated.
Hello, I know this is a pretty old post, but I am struggling with the same problem. I am also working on a 20 spline T50 and can't find the No. 3 hub sleeve or the syncho-mesh keys that go with it. Did you ever figure out if that alternate part number (33395-26010) works?
I searched hi an low for the syncho mesh keys, about three years ago, could not find any. I think the only option is used parts! Dave W
He hasn't been on here since 2011 but he'll now appear miraculously and answer.
Last edited by masterofsinanju; 19-08-2017 at 08:44 PM. Reason: Because I was wrong
FYI I purchased it from Amayama Trading Co. Ltd. (http://www.amayama.com/) in Japan and I was dealing with a guy named Justin Karow.
I still have their email from 18 May 2011 and this is the extract from that email.
>> Part numbers that have changed (same part):
33395-14013 - Sleeve, Transmission Hub --> 33395-26010
You should post some pics of your mkii. They are beautiful.
I will when I can work out how to do it.
Tried inserting an image but nothing appears.
