Results 1 to 9 of 9
Thread: LSD into Ae71
    Default LSD into Ae71
    Trying to decide what would be the best route to take in diff assemblies, i have a 4age 86kw motor t50 box and now i need a diff. I was thinking Hilux diff as they have a 4:3 diff ratio, LSD, yes( please correct if wrong ) and are strong, and cheaper than say a T18 with aftermarket 2 way or a jap LSD out of a sprinter.
    How much modifcation the hilux diff needs to get it to fit.
    i want to try to keep it sort of cheap as i'm trying to keep it in a budget, so any help would be greatfully thanked, prices and places would be good or any recomendations.
    Thanks Sav
    Junior Member Backyard Mechanic sam-131's Avatar
    Default Re: LSD into Ae71
    it'll mostly likly need to be choped and shut and the ae71 mounts swaped over to the hilux diff but remeber doing so you'll have 5 stud on the back
    any diff shop will be able to do it price differs from place to place
    south australia
    it would be much easier to fit a t-18 diff in there and fit an LSD to that.
    with the hilux diff, you would need to have the mounts cut off and re welded in position.
    then the stud pattern would be different.
    then you would need a different tailshaft.
    yopu may need to have it shortened too (?)
    go with the T-18 swap
    pedro sanchez wannabee Domestic Engineer Dom-AE71's Avatar
    if its jsut a bigport 4age a hilux diff is going to be MAJOR overkill.
    your best option is to use a t18 diff and if it doesnt have swaybar mounts, get the ones from your borg warner diff swapped over onto it then fit an aftermarket LSD center to it.
    if you want something stronger the next step up is a mx22 corona diff (f series) but your not going to need it unless your planning to put out around 160-200rwkw
    Quote Originally Posted by river
    there's many a time where someone needs just a -ve tickle and not a baseball bat
    ^^ I think that they are the same axles as the 'zenki' sprinter ones (early model, correct me if I'm wrong). LSD cetres should be relatively easy to find, but expect to pay about $1000ish for a decent one.
    I got my T-18 diff and a 4.1 centre for $70 (U-pull) and sway bar mounts for about $40, it wasn't that expensive for the setup but a LSD will add a bit.
    edited: incorrection misinformed info deleted
    scroll down to Garth's post on this link, he summarises it quite nicely
    http://www.toymods.net/forums/showthread.php?t=1371
    sorry to be a bit picky on a bit of trivia but if someone should go and buy a "kouki" centre based on that info it would be a bit of an inconvenience!
    thats very interesting
    ive been told and reconfirmed the complete opposite :S
    i actaully had my ass handed to me over the issue
    Toymods Club Member Backyard Mechanic Big T's Avatar
    Zenki is definately early model... Kouki is the late model.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
  1. AE86 hubs/rotors on AE71 struts?
    By slapper in forum Tech and Conversions
    Last Post: 07-04-2006, 08:35 PM
