Results 1 to 7 of 7
Thread: how to replace brushes in your alternator, internal reg like 22RE, 4AGE etc etc
    Default how to replace brushes in your alternator, internal reg like 22RE, 4AGE etc etc
    hi all, haven't posted here for a while as i have been driving a corona and it isn't very fast or interesting and i haven't allowed myself to do any mods to it.
    anyway i had some alternator/battery problems a while ago and managed to correctly diagnose and fix the problem, which was the battery wasn't charging, because the brushes had worn to the point where they weren't contacting the slip rings on the shaft. if your battery isn't charging and the voltage with the engine running is the same or lower than when the engine is not running then this cause should be considered.
    Usually i'd just replace the alternator but RT142 coronas aren't that common and i didn't want to pay 200 odd bucks for a reco'd alternator.
    anyway after looking at an ebay store that sold brushes and brush holders and had a brief explanation on how to replace them I pulled down my alternator and dodgied it up by extending the brush wires so the brushes were contacting the slip rings, which kept the alt working for the last month until i got the chance to buy some brushes.
    This is how i replaced them just now, pretty easy job, the guts of an alternator are pretty basic.
    First take the alternator and put it on a nice clean sheet of cardboard on the ground
    then undo the cover plate, you will need to undo the nut on the battery terminal and remove the insulator to get it off, undo the two screws either side of the brush holder, which has the orange rubber thing on/attached to it.
    Remove the brush holder, have a look at the slip rings, dunno how much gouge there needs to be to worry about replacing them and i don't know how to replace/service them, so i didn't worry about it.
    these are the worn brushes in the holder
    Here is where the brush pig tails are soldered to the terminals, desolder these and remove the brushes. if you don't have new springs, don't lose the springs when they fly out. If the brushes haven't been replaced before the solder will be covered in paint of some kind, if this is the case use a wire brush or something to get down to the solder if it is giving trouble.
    when you remove the brushes you want two clear holes like so so you can get the new pigtails through to re-solder them
    comparison of the old brush and spring to the new brush. I extended the cable of the old brush to keep my car running, which is why it looks like it does.
    Feed the new brush cables through the holes and slip the springs in the holder
    compress the springs until the brushes don't stick out on too funny an angle, then wrap the pigtails around the terminal tabs so the springs don't push the brushes back out of the holder
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Default Re: how to replace brushes in your alternator, internal reg like 22RE, 4AGE etc etc
    now solder the pigtails to the metal of the brush holder, your solder joins should look nice and shiny, not dull and shit like this. I think there was contamination from the last time i did this, still seems to work fine but could cause problems in the future.
    now you can put the brush holder back on the alternator, I used a strip of copper like so to compress the brush springs so the brushes would slide into place easily, otherwise it would have been hard to get them back on and might have chipped the brushes.
    when the brush holder is all the way on screw down the terminals and pull out the strip, instead what I did here.
    put the alternator back together
    Voltage with engine off
    Voltage with engine on, fixed!
    The voltage regulator is very easy to replace too, and looks like it would be a common part across a lot of toyotas by looking at parts and catalogs, dunno what the symptoms of a dud regulator are, apart from too high battery voltage or not charging, its easy enough to have a look and see if you have brush contact and decide if the reg is stuffed though.
    www.vicdrift.com
    nice writeup! +rep
    Been there.. Done That Backyard Mechanic Cob604's Avatar
    Aug 2007
    Great Job will save people alot of money.
    +rep
    Quote Originally Posted by roadkill
    When you get reaction like that it makes it all worthwhile.
    Bat mobil + 4age.. Engine painted, Fitting up now. Not long...
    Live life on the edge.
    Bodgepro Mechanic Grease Monkey Ghetto-Spec .:bayka:.'s Avatar
    Roadsailing, thankyou for this, that is fucking awesome. You've just saved me $200. My 4age alternator is only pushing out 7.5volts and I'm guessing its the brushes clapping out.
    Love the bodgy temp fix, i'm gonna try that first.
    Where did you get the brush rebuild kits from and how much did you pay?
    Daniel
    excellent wrtie up... this is going into the FAQ.
    I had my Camry alternator just stop working a few weeks back.
    Instead of buying new brushes, i used a 2nd hand good set from a ST162 alternator at a wrecker. Cost me $0.
    Just pull out the rubber bit, and put in the new rubber bit
    It looked identical to the one in the photo above too, so i imagine most from the late 80's & 90's with that style alternator are interchangeable.
  1. alternator + brushes help
    Last Post: 19-02-2009, 08:48 PM
  2. 4AGE head without cam caps, anything special needed to replace them?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 24-07-2008, 05:12 PM
  3. Internal regulated Alternator doubt...
    Last Post: 17-04-2006, 10:24 AM
