Hey Doc, and welcome.
What's the ultimate aim you and your brother have in mind here? I'd guess by the cage and suspension mods that you intend on doing a little track work here and there?
If so, then you'll want to stick with an NA engine.
Lets run through a few things.....
You've talked a little about the engine, but dont forget the gearbox!
The C52 box your car has now is a little conservative in the gear ratio department, so either a C56 (from a 4A-GE 20V) or C156 (six spd from blacktop 4A-GE 20v) with the CV shafts those gearboxes came with is a good upgrade. I say to get the CV shafts, cos these are equal length shafts that help reduce torque steer.
The C56 has much better ratios than the C52. It keeps your little engine right up there in the revs with every gear change.
The C156 does this even better.
As for your engine... well you have options, and lots of em.
1/ Rebuild the 4age you have now
2/ Rebuild a smallport 4A-GE (aka 100kW 4age, from AE92 SX)
3/ Build a 20Valve 4A-GE
4/ .... convert like a mofo!!
In my mind options 1, 2 and 3 are much of a muchness.... if you went options 2 or 3, they'll be pretty similar in the end if you use the same gearboxes, option 1 i think would fall behind a little in the power stakes.
If you REALLY want to have fun.... then read on...
Have you guys thought much about using a 2ZZ-GE at all? Yes they are expensive, but with 140kW output from the factory and a 6speed gearbox, it'll lay absolute waste to any 4A-GE with mild cams and headwork.
Alternatively, you could use a late model 3S-GE engine and gearbox from a Japanese fwd celica. The ST202 uses a BEAMS (iirc) 3S-GE which would be pretty gun in the teeny weeny AE82!! The 2zz is still primo choice!
Get in touch with Toby Hunt of Merridian Motorsport, he's been doing a fair few 2ZZ-GE conversions of late - it's safe to say he knows where it's at!
2ZZ ftw.
