Results 1 to 5 of 5
Thread: Oil/fluid Q"s mx83 cressida 7M auto
    Sep 2010
    adelaide
    Default Oil/fluid Q"s mx83 cressida 7M auto
    Hey all. Done a quick search but couldnt find anything on 7m trans fluid plus im useing my fone so its a pain in the arse.
    So sorry if this has been covered not long ago
    What engine oil weight is recomended?
    How much can the engine take empty filter?
    Whats the oil filter part number?
    What trans fluid is needed?
    How much fluid is needed dry?
    I have to go get this gear on my lunch break tomoz and would much rather take the advise from a forum member over the guy at autobarn
    Cheers guys
    Default Re: Oil/fluid Q"s mx83 cressida 7M auto
    Taken from penrite website
    Crankcase
    HPR 10
    or SIN 5
    or SIN 15
    Service Refill Capacity: 4.4* Litres
    Automatic Transmission
    ATF DX-2
    Service Refill Capacity: 1.6 Litres
    Differential
    HYPOID 80W-90
    Service Refill Capacity: 1.3 Litres (see note 20 below)
    Power Steering
    POWER STEERING FLUID
    or ATF TOP UP
    Radiator
    PREMIUM ANTI FREEZE ANTI BOIL
    Service Refill Capacity: 8.3 Litres (see note 1199 below)
    Brake
    BRAKE FLUID 525
    NOTES
    * Includes Oil Filter
    20 If fitted with optional limited-slip differential, use LIMSLIP 90.
    1199 Total flush required.
    Taken from castrol website
    Cars, Wagons, Utilities & Car-type 4-Wheel Drives
    TOYOTA
    Cressida, 3.0 Litre 7M-GE Eng., Automatic (1988-1993)
    CRANKCASE
    CASTROL MAGNATEC
    Castrol Magnatec 10W-40 provides up to 5 times* better protection than other leading engine oils. Up to 75% of engine wear happens while your engine is warming up. Castrol Magnatec combines synthetic technology with intelligent molecules that cling like a magnet to critical engine parts, to form an extra layer of protection. Castrol Magnatec molecules cling to the engine, to create a thin film of protection, dramatically reducing engine wear during the critical start-up/warm up period to ensure your engine is protected from the moment you turn the key. Meets and exceeds API SM/CF, ACEA A3/B3 requirements. *Tested against part-synthetic engine oils using the severe Sequence IVA wear test.
    or CASTROL GTX3 MODERN ENGINE 15W-40
    Castrol GTX3 Modern Engine 15W-40 uses the latest technology to meet the needs of today's more demanding modern engines. Designed for longer drains and/or smaller sump sizes of modern engines. Castrol GTX3 Modern Engine 15W-40 extends the life of your modern engine via providing advanced protection against high temperatures and stresses encountered in modern engines. Castrol GTX3 Modern Engine15W-40 meets and exceeds API SM/CF, ACEA A3/B3 requirements. Castrol GTX3 Modern Engine 15W-40 is suitable for 4, 6 and 8 cylinder engines built by most manufacturers since 1995.
    or CASTROL GTX2 20W-50
    Castrol GTX2 uses modern additive technology to produce extra protection for older engines requiring 20W-50 viscosity engine oils. It's liquid engineering designed for the demands of engines produced after 1990 where are 20W-50 viscosity is required. Castrol GTX2 extends the life of your engine, provides advanced protection against higher temperatures and stresses encountered in post-1990 engines, is compatible with catalytic converters and oxygen sensors, made from premium quality base oils and additives and helps minimise oil consumption. Meets and exceed API SM/CF. Suitable for petrol, LPG or CNG cars, light commercial vehicles and 4WDs where API SM/CF or earlier specifications are recommended.
    Service Refill Capacity: 4.4* Litres.
    AUTOMATIC TRANSMISSION
    CASTROL TQ DIII
    Castrol TQ DIII is an automatic transmission fluid formulated to satisfy the GM H-36163 specification, and suitable for automatic transmissions requiring a GM fluid. Not suitable for use where DexronŽ VI fluids are required.
    Service Refill Capacity: 1.6 Litres.
    DIFFERENTIAL
    CASTROL EPX 80W/90
    Multipurpose gearbox, steering gear and differential oil for passenger cars, light trucks, farm tractors and earthmoving equipment. SAE 80W/90, API GL5.
    Service Refill Capacity: 1.3 Litres.
    See note 20 below.
    POWER STEERING
    CASTROL PS FLUID
    A mineral based fluid suitable for most power steering systems where the following specifications are nominated: DexronŽ, DexronŽ II & DexronŽ III, SAE 10W or 10W-20 engine oil, ISO 32 or 46 hydraulic oil, Ford M2C-33 F/G, Ford M2C-138 CJ, Ford M2C-166H, Ford Mercon, Ford SQM-2C-9010A and Mitsubishi Power Steering Fluid.
    See note 516 below.
    RADIATOR
    CASTROL ANTIFREEZE-ANTIBOIL
    A fully formulated, ethylene glycol based coolant designed to meet the requirements of the majority of cars and light commercial vehicles with petrol and diesel engines. Use at 30 - 50% concentration as recommended by the vehicle manufacturer.
    Service Refill Capacity: 8.3 Litres.
    See note 1240 below.
    BRAKE
    CASTROL BRAKE FLUID HD DOT 3
    A heavy duty brake fluid suitable for use in disc and drum brakes where a dot 3 fluid is required.
    NOTES
    Includes Oil Filter
    20
    If fitted with optional limited-slip differential, use CASTROL LSX 90 or CASTROL SAF-XA.
    516
    May also use CASTROL TRANSMAX M, CASTROL TQF or CASTROL TQ DIII.
    1240
    Do NOT mix Castrol coolant with other brands of antifreeze, coolants or corrosion inhibitors because of possible incompatibility of inhibitors. Follow manufacturer's recommendations for coolant concentration.
    Sam
    Sep 2010
    adelaide
    Legend mate i didnt even think to look on the oil sites cheers for going to the trouble
    Sep 2010
    adelaide
    Wouldnt mind knowing how much the trans roughly holds as all my lines, trans etc are empty
    May 2006
    tas
    if you look it up in the book at the shop that your going to they normally have a it, fairly sure they had it when i brought some then never used it.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
  1. JZX90 Auto / S1 MX83 Cressida Trans Troubles
    By PsyCo in forum Tech and Conversions
    Last Post: 18-09-2010, 01:00 PM
  2. MX83 Cressida Gearbox Problems
    By johnnilicte in forum Tech and Conversions
    Last Post: 15-06-2006, 08:36 PM
