Results 1 to 8 of 8
Thread: MKIII supra swap questions
    Oct 2010
    Georgia
    Default MKIII supra swap questions
    i have a 1988 supra with a 7m motor and i am interested a 1jz motor swap. i like the one they have listed on osakajdmmotors but it says it comes with a a/t and i have a manual. with a new bell housing will that motor work? what else will i need to buy to make it work? i want to keep the manual tranny and as much as i can on the car. the motor i have has bad compression due to a bad piston ring on cylinder 2. i am looking for a lil more power also. what would y'all recommend?
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    Default Re: MKIII supra swap questions
    if its a jza70 a/t halfcut you can run it with the 7M R154 box but yes you will need a new bellhousing.
    most importantly though when you're wiring it up you'll also need to wire the ECU in a way to trick the neutral start switch on the auto box (as its not there..) so the ECU is effectively given the green light to start her up. theres a writeup on that somewhere on the forums here im sure of it.. just search for it.
    This might help though -> http://www.toymods.org.au/forums/showthread.php?t=1593
    Apologies though, the guy who wrote it was a bit of a todger.
    This is a better writeup -> http://www.toymods.org.au/forums/showthread.php?t=64
    EDIT: i just noticed you're in the US.. you might have issues with your steering column side also clearing the intake.. not sure on that but check with the SupraMania guys on that one as were all RHD vehicles here not LHD.
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
    Oct 2010
    Georgia
    this is a newb question i no, but whats a halfcut lol. this is what im looking at. and yes, its american money
    http://www.osakajdmmotors.com/jdm-en...c269cc68f16e05
    May 2008
    Thats a front sump so mosy likley from a jzx90 etc. you will need rear sump, jza70 engine mounts or driftmotion mounts, will need to lengthen the ecu wiring etc join up supramaina lots of info
    1992 - JZA70 STOCK - SOLD
    half cut would be best but prob not needed, just tell the place you are buying the motor from what you intend on doing and ask for all the parts you will need!
    Quote Originally Posted by JZA70R_92 View Post
    jzx81 actually... 90's have TCCS.
    so JZA70 is rear sump config?
    May 2008
    yeah JZA70 is mid rear sump can use sump from jzz30
  1. 18RGU to Hilux engine swap questions
    By smokem1 in forum Tech and Conversions
    Last Post: 27-11-2007, 12:06 PM
  2. Write-up/How to: AE86 SR-5 to GT-S swap. ***No 56k***
    By assassin10000 in forum Tech and Conversions
    Last Post: 11-06-2007, 04:32 PM
  3. 1GGTE into RA65 Questions.
    By Ashe in forum Tech and Conversions
    Last Post: 20-11-2006, 07:51 PM
