Results 1 to 4 of 4
Thread: Slight crack in cast alloy part of sump
    May 2008
    Default Slight crack in cast alloy part of sump
    Hi guys
    Finally fitted the 1J into my new shell and noticed there is a slight cracke on the alloy part of the sump now it hasnt opened up but is a crack could have been caused by the front ender the car had before. now its been like that for 1 year. can it be tigged up??? also as i NEED to drive it would can I use on it at this stage ive smothered it in silicon lucky for me its not on the steel bowl of the sump!!!
    1992 - JZA70 STOCK - SOLD
    Aug 2009
    Default Re: Slight crack in cast alloy part of sump
    can be tigged up if its removed from the engine obviously.. but if its on the car, i would clean the shit out of it with brake cleaner (or fuel, anything that evaporates without leaving residue), and use aliminium devcon
    ive used it for transmission coolers on bmws as there a little aluminium can type looking thing that clips into the radiator and has water running through it, people bump kerbs or a decent rock flicks up and they weep oil... never had one come back
    Penrith BC
    tip, grind a groove along the crack with a dremel/die grinder before devcon/loctie metal filler
    ../delete/ban
    tech moderator
    May 2008
    cool cheers for the tips. I used some jbweld cleaned area with wire brush and brake cleaner also as it was inline with the bolts that hold on the powersteering fluid line to the alloy part so I made a steel plate that bolts up with silicon for extra insurance. have given WTF auto a call and they say then can tig it up so will visit them when I can! thank goodness it at the higest point and low pressure area!!!
  1. 2JZ Front Sump Part Numbers
    By Viper in forum Tech and Conversions
    Last Post: 12-05-2009, 12:21 PM
  2. Cressida MX73 Conversions Guide Book
    By twentyEight in forum Engine & Driveline Conversions
    Last Post: 24-02-2007, 10:07 AM
  3. Machined vs cast part
    By wagonist in forum Tech and Conversions
    Last Post: 30-01-2007, 06:00 PM
