Results 1 to 6 of 6
Thread: 1JZ water pump outlet
    Professional Amateur Grease Monkey sil80 1J's Avatar
    Feb 2008
    Default 1JZ water pump outlet
    Does anyone know where the small outlet at the back of the water pump, facing diagonally down towards the chassis rail on a soarer goes to or comes from?
    thanks
    Sil80 1JZ chasing 400rwkw
    Update: 4/5 the way there on 21 PSI, 350.3rwkw
    http://i112.photobucket.com/albums/n...L801copy-1.jpg
    May 2007
    Default Re: 1JZ water pump outlet
    pretty sure it goes to the turbo water lines...
    the 2 bolt one goes right round the back of the block
    the big one goes to the radiator
    the others go to turbo water lines...
    the one on the front behind the pulley doesnt go to anything but will start leaking when the pump is fucked
    Feb 2008
    so you mean it links up with the 2 that feed the turbos from the top cast section that runs into the top of the radiator?
    May 2007
    no... it should run to the front turbo its like a u shaped hose IIRC
    the 2 on the upper housing go to the 2 hardlines along the top... see my members ride thread and you will see a picture of the top 2...
    Feb 2008
    interesting, i wonder why the front turbo? i have a single turbo on my 1j and im just wondering where to plumb that hose into, currently i have it blocked but i dont think thats all that good, ide prefer to have it going somewhere useful
    May 2007
    there is an outlet on the hard metal line that runs around the back of the block that goes to the rear turbo...
    on my single setup this one at the rear has been deleted (cut and welded up)
    the 2 on the upper have been cut and welded up and a new one has been placed facing downwards (allows more clearance for the inlet pipe)
    i have the one you have questioned feeding my turbo water line and the other side runs to the new downwards facing nipple on the upper neck...
  1. Replies: 1
    Last Post: 15-02-2009, 08:33 AM
  2. 2JZ Water Pump onto 1JZ
  3. 1jz hydraulic water pump fluid?
    By mr_mike in forum Tech and Conversions
    Last Post: 27-04-2007, 04:28 PM
