Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Tech Tip - Getting the Spigot Bearing Out (when you don't have a bearing puller)
    Thumbs up Tech Tip - Getting the Spigot Bearing Out (when you don't have a bearing puller)
    Here's a relatively easy way to get the spigot bearing out of the back of the crank (which is worthwhile whenever you do a clutch swap).
    1) Get a bolt that neatly fits through the centre of the bearing.
    2) Rip up newspaper into small pieces and soak in water until wet.
    3) Start to push the newspaper into the bearing and hammer in using the bolt.
    4) Keep doing this and after about 10-15 minutes you will see the bearing start to push out. After about another 5 minutes of hammering in the paper the bearing will fall out.
    5) Clean out all the newspaper and fit a new bearing.
    EASY!
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    Default Re: Tech Tip - Getting the Sigot Bearing Out
    Or...Use a bearing puller
    I knew someone would write that. The point is that most of us don't have a bearing puller so this is a great way to get around the problem rather than having to wait until the next day to buy one.
    Quote Originally Posted by Grant
    Yep and it had to me
    Yeah I know. It is a good idea and you got the +'s for it
    Default Re: Tech Tip - Getting the Sigot Bearing Out (when you don't have a bearing puller)
    Thanks. I modified the header now too.
    There is also a spelling mistake in it
    Good tip, packing it full of grease also works to the same effect.
    what? Automotive Encyclopaedia EVOSTi's Avatar
    yeah i think grease would take about half the time than ripping tiny pieces of paper and putting it in. also a quicker way if you dont have a slide hammer (get one they are cheap and handy to have) is to get 2 bolts, usually the ones with the 12mm heads are a good size. put one in the hole, then HAMMER the second one into the same hole, then leaver out with something or sometimes you can hit it sideways with a hammer.
    Grease = messy
    Seal pulley = god
    sa
    Grease is the best method. I'm not sure how effective a bearing puller would be considering the size of the hole.
    you spigot bearing musnt be in too hard if you can get it out with seal puller.
    Ok, let me rephrase, seal puller + treat it like a slide hammer = teh win.
    sa
    but why?
    The grease method might be a little messy, but it's guaranteed to get it out with no headaches. Hydraulics beat slide hammers any day.
    cept slide hammer takes all of 10 seconds.
    I once had no luck with the grease + bolt method (only because I managed to hammered the bearing in cocked..... Bigworm FTL) and ended up using a dyna bolt + slide hammer, which worked a treat.
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    I tried to hydraulic one out of a dyna crank the other day at work
    Bearing full of grease, check
    Bolt that fits snug, check
    Hammer, check
    Commence wacking, check
    Grease coming through bearing!!!???! WTF
    Then a co worker told me that we have bearing puller, DOH
    Bearing puller for the win, although ours only just fit into the hole of the bearing, which has the same inner diameter as a t50.
    dan
  1. DIY: Transmission Rebuild *** No 56k ***
    By assassin10000 in forum Tech and Conversions
    Last Post: 30-05-2007, 12:07 AM
  2. Avante/TA22 rear disks - bearing retainer
    By TwentyTwo in forum Tech and Conversions
    Last Post: 27-06-2006, 03:21 PM
  3. Corona MK11 wheel bearing size???
    Last Post: 06-03-2006, 10:34 AM
  4. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
  5. engine bearing for 18rg
    By bullitt in forum Tech and Conversions
    Last Post: 05-12-2005, 10:54 PM
