Results 1 to 7 of 7
Thread: MX83 tacho, aftermarket ecu????
    Default MX83 tacho, aftermarket ecu????
    Hey guys.
    I'm running a LINK ecu with my setup and i want to run the dash tacho as an output from the ecu. The problem is that the ecu will not drive the factory tacho as the original 7m run off the coil and provided a stronger signal then the LINK provides. The question i ask is, does anybody know how to modify the factory 7m tacho to accept the signal sent from the link. It would be exactly the same as modifying it to accept the 1j signal without a booster.
    Hope someone can help.
    MX83 Grande 1jz GT35R buildup here.
    http://www.toymods.net/forums/showth...ghlight=grande
    Some say that his heart has 6 cylinders. All we know, is he's called,
    Default Re: MX83 tacho, aftermarket ecu????
    This is what Ray recommends when using a vipec:
    http://www.tfelectronics.com.au/bin/Tachoadaptor.gif
    KE70 7AGE Grease Monkey jet81j's Avatar
    this looks a bit simpler
    i didn't pull the relay apart i just hooked it to the coil and didn't use the other points.something i also found the relay was really noisy so i had to put the relay in the engine bay.
    this worked perfect for me but this was on a stock ke70 tacho and adaptronic computer but should be the same.
    i know i can make a signal booster but i remeber someone actually modifying the tacho to accept the new signal.
    Jan 2009
    sa
    yer, i had my tacho board replaced by gauge works.
    basically they modified the board in the tacho to work from the signal required.
    just send in your dash cluster.
    http://www.gaugeworks.com.au/contact_us.html
    also this way will be more accurate than making a adapter, i was told.
    When using a coil from a relay, you are best to crack it open and cut the switching side off it so it isn't noisy.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
  1. makign a 1jz loom for aftermarket ecu
    By Disturbed1 in forum Tech and Conversions
    Last Post: 07-06-2009, 03:34 PM
  2. aftermarket ecu options for 4agte?
    By phil in forum Tech and Conversions
    Last Post: 07-08-2008, 02:25 AM
  3. 4 Cyl ---> 6 Cyl Tacho Swap.
    Last Post: 30-01-2007, 10:36 AM
  4. 1jz Aftermarket Ecu
    By thommo in forum Tech and Conversions
    Last Post: 27-01-2006, 10:09 AM
