Page 1 of 3 123 LastLast
Results 1 to 15 of 37
Thread: 1ggte workshop manual
    N.S.W
    Default 1ggte workshop manual
    after 1ggte/i1ge workshop manual that was floating around on the forums. Tryed searching but all links are dead, and yet again my computer fucked up and had 2 be formatted
    cheer, michael
    Default Re: 1ggte workshop manual
    engine mechanical (4.13mb)
    or
    service specs (679kb)
    send me your email and ill email them to you
    Long Time Reader Backyard Mechanic willwal98's Avatar
    Would also appreciate a copy of both of those if they are in English. I'll pm you my email.
    Hello.
    service specs are, engine mechanical isnt, but the pictures are pretty informative and you can always translate it.
    headgasket tightening pattern is interesting too.
    Feb 2010
    Here you go. These are the same as love ke70's.
    http://rapidshare.com/files/34710717...cations_2_.pdf
    http://rapidshare.com/files/34710861...hanical_2_.pdf
    Let me know if they don't work, first time using rapidshare.
    N.S.W
    yeh mate those links work and thnks loveke70
    Aug 2009
    Thanks for these.
    Project:RA65 with an engineered 1ggte conversion.
    Daily:MA61 - 5me stock auto shitheap.
    Mar 2010
    Is there a program on the internet i could use to translate these manuals from Japanese to english?
    Aug 2010
    KAIKOHE, NEW ZEALAND
    hay guys i am new to this just got me a toyota surf with a 1g-gte in it and i am looking for a work shop manual and like to talk to some one who knows alot about these motors i only know about holden motors can any one out there help me
    dont those links work up there ^^
    what do you want to know about these motors?
    plenty of info on here
    cheers, andy
    Aug 2010
    well it ant got the balls it should have but it smokes a bit when you rev it i think the ring mite be stuffed i am not sure i have another 1g-gte for it but cant find any pistons for the motor in nz and a work shop manual for one of these motors would be great
    the links are just up there ^ for the workshop manuals
    r u sure the turbo is not the cause for the smoke?
    get it compression tested and give it a quick dyno run, see what its making and the sorta mixtures its running, then they should be able to give you some suggestions.
    ive got pistons i could sell you, im going forgies, slightly scuffed but should be right.
    doesnt toyota sell them?
    Yeah, smoky under revs is pretty common. Most commonly it's valve stem seals or turbo seals.
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    Aug 2010
    yea will do thanks for that if it not rings i have spear turbos off other motor thanks for the help i must put some photos up of it . it looks mean with a 4inch body lift
    Aug 2010
    cant be valve stems head was rebuilt before i got it but thanks for the help i will sort it out . nah toyota dont make them any more over here hay how much are the forgies over there?
