Results 16 to 20 of 20
Thread: How to convert a c160 box for mr2 AW11
    Sep 2009
    Default Re: How to convert a c160 box for mr2 AW11
    Note - the flat on the c60 selector shaft positions the cable linkage approx 10 mm further out from the centre of the box. Until I fit the cables, I won't know if that's going to be a problem. If necessary, I'll modify the cable mount on the engine.
    Sep 2009
    Talking Finished and installed
    Update : the gearbox is in!
    The chassis mount was within 1mm, and the aw11 shift cables mated perfectly. All 6 gears and reverse can be selected with no problems.
    The c160/blactop combination has an alloy stiffener that joins the lower block to the gearbox. This needs to be ground away to clear the aw11 rhs drive shaft - I removed approx 8 mm of metal, but managed to do so without any issues.
    A successful conclusion.
    Thanks to Aaron Willis for help with part selection for the gearbox, and John Ellis for fabrication of mounts & brackets.
    Sep 2009
    Final update (unless it breaks) : car is on the road, all gears select smoothly. Combined with the 20v blacktop, it's a very balanced package.
    May 2008
    vic
    Excellent write up.
    I just sent you a PM. How's the MR2 coming along? I'd be very interested to have a chat and a look at it one day if your free. I'm also in eastern suburbs of melb.
    Apr 2017
    kingston
    Hi. Im missing the bracket for the shifter cables. Can you please say how you solves this situation. Please if you have pictures.
    Sent from my SM-G925I using Tapatalk
  1. Unequal and Equal length drive shafts.... AW11
    By kassma in forum Tech and Conversions
    Last Post: 24-07-2009, 07:37 PM
