Results 1 to 3 of 3
Thread: 1975 MS85 Toyota Crown automatic fluid litres
    Jan 2008
    Default 1975 MS85 Toyota Crown automatic fluid litres
    Hi Folks, I have a problem with my 1975 automatic Toyota Crown, 2 days ago I drained the auto transmission fluid and then set about filling it as per the instructions from a 1968 3 speed Toyota Crown automatic manual and it states the transmission takes 7 litres of fluid.
    I first filled it with 5 litres as it states and then warmed up the engine and then set about adding the last 2 litres but after another litre it overflowed so I'm wondering if the 1968 3 speed auto is the same as the 1975 3 speed auto or does anyone know how many litres should the 1975 model take.
    Any assistance would be greatly appreciated as we are about to go on a touring holiday this Saturday towing the tear drop camper.
    Cheers Owen
    Apr 2007
    Default Re: 1975 MS85 Toyota Crown automatic fluid litres
    I would say the manual would be to referring to a dry fill as in a empty converter etc, when you drain the pan the converter still has the old oil in it, just go by your dipstick now, drain out the excess, run the car through the gears & recheck on level ground & do a final check preferably once the trans oil is all warmed up again level ground etc ..
    Jan 2008
    Oh your right I forgot all about the convertor and thats why after I filled it with 5 litres the dip stick read full but about 20 cms above the full mark, I drained all the fluid again this morning and degreased all the over flowed fluid. This arvo I'll add the fluid by the litre and then check the stick. Thanks for the assistance its really appreciated.
  1. Toyota Crown MS53 Crown Custom Wagon
    By TheToyman75 in forum Tech and Conversions
    Last Post: 23-06-2011, 12:44 PM
  2. Toyota Crown MS63 Custom Wagon Info
    Last Post: 28-09-2007, 01:31 PM
