Results 61 to 64 of 64
Thread: Shrike the 4wd ae111 build log
  1. #61
    Oct 2009
    Default Re: Shrike the 4wd ae111 build log
    Hmmm been a while since I posted, had a few things on another forum that has now died :s
    Not sure how many people are on here still however
    Coming back to NZ over Easter to see Steve and get a timeline worked out to get the car finished. I am still in no rush but need to see some progress happening
    Chassis has been seam wielded and prepped for a 6point cage (all glass removed etc) but not had many updates otherwise.
    I have had a few things taking priority so haven't really chased it, looking at buying another house in the next few months along with moving up the chain some more work wise.
    Did a rough outline of what it will cost me for (and then doubled it )
    ECU (Probably a Haltech 2500 at this stage) and Tune
    Fuel system
    Engine (9A) and clutch
    Boost sources and control etc
    Tires
    Electric steering
    Rear brakes
    Hans and another race seat
    Carbon fiber bits
    Aftermarket Front/Center and rear diff (if the budget stretches) otherwise it will be after its all running
    Probably missed a few things but the list is slowly getting smaller
    Don't want to say how much but its about what I thought. in hindsight could have gone and brought a few other cars but oh well (Still could but this car has emotional attachments for me)
    And to be fair I would have gotten similar results with other platforms, don't plan on ever selling this car either so hopefully I get the enjoyment when its finished
    Funny how things snowball when you want to do them right the first time
    Just ordered front brakes and RCA ball joints from Barry (MRP) Wilwoods, 328x28mm rotors, all parts to fit and braided lines etc
    Looking at options for a rear setup but will probably end up with ST205 rear discs and either factory ST205 rear calipers if I can find some or a wilwood item
    Evo X rotors are a close match so investigating those atm
    Will post more pics over Easter still a lot to do
  2. #62
    Oct 2009
    For anyone with an st185 or st205
    My 5x114.3 conversion(mentioned in previous posts) uses
    Front Rav4 drive flanges
    Rear Toyota Highlander bearing and drive flange package
    Front brakes are Ba falcon 329x28mm rotors with wilwood 4pots from MRP (discs need spacer/locator ring and adapters for calipers) but its there st185 kit setup for 5x114.3
    Rears are going to be z34 370z 350x20mm rotors (work with factory 170mm handbrake) (discs need spacer/locator ring and adapters for calipers) and remanufactured 370z Brembo 2pot calipers from Stop tech, could also go for the z33 350z 322x22mm
    You can also use Z32,R32,R33,R34 rear Rotors (290mm) with the factory handbrake with nissan 2pots adapters etc required
    Apart from custom braided lines, caliper adaptors and locating/spacer rings
    Parts are common and off the shelf
    Pads, discs, calipers, caliper rebuild kits etc
    Hope this makes sense
  3. #63
    or ST215 or ST246... Cos the brakes are well underdone on these...
  4. #64
    Oct 2009
    Update from facebook
    Looks like the project car is getting some more progress, test fitting the non built 7afe dummy engine from an ae115 with the awd box for transfer-case clearance. I also have a rebuilt GT4 gearbox for when the 9a motor goes in which will have the bell-housing off the E series 4agze box I have spare.
    Steve will be making me new chromoly sub-frames front and rear to reduce weight and allow for transfer case/diff, we have discussed cutting the floor for clearance but hoping it doesn't need it. Once that's mocked up it'll be cage time shell has already been seam welded
    Still need to order fuel system and a few other things
    Looking forward to seeing more updates
    Current goals are to get it rolling and as many parts on as possible. Tbh if the 7afe actually runs it may stay in it for a bit haha just to move it round
    Also a pic of the seat sitting in it from when I was there over Easter
    On the table
  1. How to install an adjustable 1JZ cam gear in 1.5 hours
    By Mr DOHC in forum Tech and Conversions
    Last Post: 17-06-2012, 08:39 PM
  2. loosing power on higher gear?
    By normality78 in forum Tech and Conversions
    Last Post: 27-02-2008, 01:19 PM
  3. T-18 running gear into TA22??
    By walt in forum Tech and Conversions
    Last Post: 19-01-2008, 12:51 AM
  4. AE86 "Cusco" quick steering racks??
    Last Post: 02-06-2007, 01:13 AM
