Results 1 to 6 of 6
Thread: 4agze aftermaket ECU, worth it?
    vic
    Default 4agze aftermaket ECU, worth it?
    hello,
    i just wanted to know it is worth is to put an after maket ecu on to my 4agze.
    i have a 175mm crank pully and i would like to upgrade to a sc14 one day, but should i get the computer now will it make any inprovment in the power i already have?
    and if so where is the best place in melbourne to get this done?
    and what is the best ecu for a 4agze?
    Default Re: 4agze aftermaket ECU, worth it?
    It wont make a huge improvement just yet. The mixtures are pretty good even with a larger pulley.
    That said, if you are seriously considering more mods then i woudl suggest that you start shopping around to see if you can get a good price.
    Not sure who would do installs in Melb, but Bennica Motors have always been good for racing bits, especially on Alfas and other Italian cars. I think they do Autronics thoguh, and probably a bit rich for most people.
    I'd say worth it for sure. I gained 8hp in straight before-and-after runs just with fuel tuning on a $80 fuel/air controller after putting on a 165mm pulley, so I think the gains would be awesome with a good managment setup. Plus you can delete the AFM etc...
    RM.
    Junior Member Grease Monkey craigy's Avatar
    Im setting up a wolf3d setup on my GZE, and plan on using speed technology in melb's to tune. They dont seem to be too expensive should cost about $400 to tune, but i already have a map.
    4AGZE powered AE86
    SR5 dual cab Hilux
    265 powered VJ Valiant Charger
    Junior Member Carport Converter 4agte's Avatar
    id say definatley mine made a heap more power with an aftermarket computer plus leaves scope for more mods down the track
    edit: with the removal of the afm you get some awesome s/c intake whine
    rollamatt86's is already a map sensored type so there is no afm
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
  1. TVIS not engaging due to ECU?
    By phrostbyte in forum Tech and Conversions
    Last Post: 03-03-2006, 12:39 PM
  2. 4agze conversion
    Last Post: 02-03-2006, 09:52 PM
  3. Can the ECU get a fault wrong?
    Last Post: 28-02-2006, 01:28 AM
  4. 1JZGTE ECU Part Numbers
    Last Post: 13-02-2006, 11:31 AM
  5. How to connect 20V alt to 4agze loom?
    By d-shiznit in forum Tech and Conversions
    Last Post: 25-11-2005, 08:10 AM
