Results 1 to 5 of 5
Thread: Coil Pack Compatibility?
    Not a patch on a Backyard Mechanic
    WA (Perth)
    Default Coil Pack Compatibility?
    As Mulder said from the X-Files - I just want the truth....
    I remember reading on the old forum that 7M-GTE, 4A-GZE and 1G-GZE coil packs are compatible....is this the case?
    Or does it only apply to specific years / series?
    Thanks,
    Mitch.
    RA23
    1G-GZE
    Default Re: Coil Pack Compatibility?
    I know that 7MGTE and 4AGZE coilpacks are compatible. I had a 7MGTE coilpack on an old GZE i worked on. Not sure about the 1GGZE.
    Oh yeah, early 4AGZEs used single spark coilpacks with a dizzy, so you cant use those.
    they might have different part numbers but are essentially the same part - 4agze (with DLI ignition not a dizzi) and 7mgte are definately the same.
    1ggzi is probably the sam, the igniter works the same way as the 7mgte unit.
    WA (Perth)
    Thanks guys, this gives me a starting point - much appreciated.
    RA23
    1G-GZE
    Yes, 1GGZe coil packs are also the same.
  1. Coil for High Energy Ignition
    By Tham in forum Tech and Conversions
    Last Post: 24-05-2006, 12:29 AM
  2. checking timing on car with coil on plug setup
    Last Post: 23-02-2006, 06:52 PM
