Results 1 to 6 of 6
Thread: 1jz non VVTi - 1jz VVTi differences?
    Default 1jz non VVTi - 1jz VVTi differences?
    just looking into the differences between them,
    i know the heads/manifolds are different,
    but what about block? engine mount brackets? bellhousing bolt pattern? sumps?
    any help greatly appreciated,
    cheers, Blake
    Mobile Backyard Mechanic PeteH's Avatar
    May 2007
    Default Re: 1jz non VVTi - 1jz VVTi differences?
    Bellhousing and sump bolt pattern is the same for both VVTi and non.
    On the VVTi there are an additional set of mounting holes cast/tapped into the right hand side of the block. I had to use the holes closest to the front when bolting the VVTi into my MX83.
    Hope that helps.
    Pete
    how bout flywheels? they interchangeable?
    cheers!, Blake
    Quote Originally Posted by IN 05 NT View Post
    cheers!, Blake
    Flywheels = same.
    Wilbo's JZA80
    Wilbo's JZZ12
    Timing belt assembly? Whats different in that area?
    May 2007
    Quote Originally Posted by jeffro ra28 View Post
    Any part in particular?
    Timing belt - Same
    Tensioner - Same
    Idler - Same
    Pete
  1. Power FC for VVTi 1JZ
    By whatthe? in forum Tech and Conversions
    Last Post: 24-01-2007, 01:45 PM
  2. MZ20 A340E behind 1jz VVTI?
    By JZA20 in forum Tech and Conversions
    Last Post: 24-07-2006, 07:22 PM
