Results 1 to 15 of 16
Thread: 86 AE86 SR-5, Check engine light
    Jul 2009
    TEXAS
    Default 86 AE86 SR-5, Check engine light
    can anyone tell me why my 86 corolla sr5 does not have a check engine light, nor a place for one in the cluster? i figured it would have a dummy light even though its a 86, my 84 porsche had one, very strange
    2003 Subaru Wrx, Modded DD -- Project Grip
    1986 Ae86 -- Project Sideways
    Default Re: 86 AE86 SR-5, Check engine light
    Because it doesn't have a computer to output error codes: no check engine light needed.
    If its anything like an aus spec ae86, when you do a 4age conversion you will need to hook up an extra light connected to this pin on the ecu.
    sr-5 probably has a carry over dash from the ae85 which wouldn't need a check engine light on any model.
    Jul 2009
    TEXAS
    so what does the one wire 02 sensor report back to?
    Traditionalist Domestic Engineer parrot's Avatar
    There is a pin on the ECU.
    Download the diagnostic manual from the link on aeu86.org I gave you previously. It has simplified wiring diagrams that make it clear.
    Cam mountain I feel different from the ordinary
    Jul 2009
    TEXAS
    robertx says there is no ecu?
    i was curious so i looked up wikipedia ..
    SR5 specifications
    * Chassis Code: AE86
    * Horsepower: 87 hp (64 kW) @ 4800 rpm* Torque: 85 ft·lbf (115 N·m) @ 2800 rpm*
    * Weight: approximately 2200 lb (998 kg) to 2400 lb (1089 kg)
    * Engine: 4A-C, 1587 cc
    * Engine Type: SOHC 8-valve Inline-4 Carburated
    * M/T Transmission: T50, 6-bolt flywheel
    * A/T Transmission: A42DL, 4-speed overdrive w/lockup torque converter, mechanically controlled, with electronically engaged overdrive
    * Compression: 9.0:1
    * Differential: 6.38" Open with 4.10:1 Ratio, 2-pinion (Automatic) (S292) or 3.91:1 Ratio, 4-pinion (5-speed) (S314)
    * Wheels/Tires: 13x5" +33 mm Offset Rims with 185/70-13 Tires
    * First 7 Digits of VIN: JT2AE86
    Being wikipedia i can't guarantee this info is actually correct
    The GT-S got the 4AGE
    Jul 2009
    TEXAS
    yeah, that info is dead on, and a nissan sunny conversion? thats a first for me
    Quote Originally Posted by jdm03wrx View Post
    that being the case then its carbied so won't have a check engine light
    nissan sunny conversion? Thats our equivalent of a pulsar isn't it?
    Jul 2009
    TEXAS
    Ah, according to the diagram there is no check engine light, nor ecu, but there is an emissions control computer
    Quote Originally Posted by parrot View Post
    Jul 2009
    TEXAS
    because it failed the texas emissions test because of lack of a check engine light, now i just have to bring in documentation that the car was never equipped with this light. We dont have the nissan sunny over here in the states either, over here its called the sentra but never came turbo not to sure on the pulsar, the pulsar here looked a heck of a lot different than either and came with a 1. something non turbo
    RobertoX is saying it has no computer because he is referring to the SR5 cluster. SR5's didn't have a 4AGE so no computer to send a signal to a check engine light. Therefore no check engine light.
    If you want a check engine light you need to source a GTS cluster, and have a 4AGE with factory computer wired to it.
    The oxygen sensor has nothing to do with the cluster.
    There is an oxygen sensor on your 4A-C?
    Jul 2009
    TEXAS
    Quote Originally Posted by RobertoX View Post
    yes there sure is
    Californian emissions spec. We never got a Cali equipped 4A-C over here, and hence why we have no idea what you are talking about.
    Jul 2009
    TEXAS
    I never said the o2 sensor had anything to do with the cluster, what I was simply asking was if there was an ecu?(which there is not, there is only an emissions control computer) I am very aware that the o2 sensor would not directly connect to the cluster. I dont want a check engine light or need one for that matter. If the car never came with one then I do not have to have it to pass my emissions test here in Texas, what I was unsure of is if somebody could have possibly switched the cluster out for one in an older car or japanese model. But thanks for all of everybodys help, I think I have the info I need
  1. 5M E to 5M GE/6M GE Conversion Guide
    By spiller in forum Engine & Driveline Conversions
    Last Post: 29-11-2011, 12:03 PM
  2. 2JZGE in MX83 (check engine light comes on)
    By RObErT_RaTh in forum Tech and Conversions
    Last Post: 11-08-2009, 07:02 PM
  3. JZA80 check engine light and hazard light coming on randomly
    By VasH in forum Tech and Conversions
    Last Post: 24-10-2008, 12:24 AM
  4. MA70 --> JZA70 Conversion
