Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: help choosing a 3sgte (and ta22/3sgte talk)
    May 2009
    New South Wales
    Default help choosing a 3sgte (and ta22/3sgte talk)
    Ok, so i have decided to go down the route of the 3sgte conversion in my 74 ta22
    now, i am going to get straight to the point:
    there is a GenIV 3sgte halfcut of a Caldina st215 on ebay at the moment for cheap
    my understanding is that this engine does not have the dizzy which will foul my firewall when it goes into the ta22. which = good
    Is this even worth looking at? or just a waste of time?
    dont really have anyone else at hand to get a second opinion from at the moment
    any input would be much appreciated
    Joel
    1974 Ta22 Celica - sold
    1989 AE92 Corolla SX with AE101 4AGZE - Daily
    Default Re: help choosing a 3sgte
    It is the best 3S-GTE to choose.
    RWD conversion should be the same process as done on any other 3S-GTE.
    Electrics could be tricky though.
    May 2009
    New South Wales
    what about finding things like parts?
    the add states that the engine has done 147 thou k's so I would be looking at pulling it apart checking everything and replacing anything that is a bit worn
    when i look around at various parts for the 3sgte, they all state that they support either the st185 or the st205 etc etc, but they never mention the st215, so will i have much trouble finding things like main or big end bearings (if i was wanting to replace them as an example)
    not wanting to get too involved with the ta22/3sgte conversion (im pretty sure i have that covered) and yeah, electrics will be awesome to tackle (sarcasm)
    I am kinda wanting to know whether a 147 thou km engine is worth my time and money looking at, and if it will be a nitemare trying to find parts (or if genIII or other parts will fit if required)
    thx
    Last edited by Element88; 05-08-2009 at 08:17 AM. Reason: its a ta22 not a ra22 haha
    Tasmania
    gen 3 and 4 are for all intensive purposes the same, bearings etc, so go for it.
    difference being gen4 runs COP and CAS not dizzy as you have said.
    1973 TA22
    May 2009
    New South Wales
    hmmn, sounds very promising
    thnx for the info guys
    now have to bargain for some shed space
    Joel
    Nov 2007
    Caldina gte has turbo exhaust housing as part of the manifold, so you'd have to go for a new turbo, but you'd likely be doing that anyway. Other than that, the caldina one is probably the best although i've not found much issue with converting the gen 3 either. Sump and clutch were the biggest issue.
    Quote Originally Posted by Cuts View Post
    don't forget top feed injectors and higher comp pistons 9.0:1 instead of 8.5:1 in the Celica's, a turbofold, side inlet manifold and a remote mount oil filter.
    Jordan
    Tasmania
    of course since this is going into a ta22 the inlet mani and exhaust/turbo setup have to be changed anyway.
    remote oil filter i didnt know about...learn something new every day.
    1973 TA22
    Teaser pics to help you up make your mind.
    With the turbo you can put a 7MGTE CT26 exhaust housing on the exhaust side instead. Granted it will be a bit worse than the unmolested stock turbo as there is more gap between the exhaust wheel and the housing. It will also not be as good as an after market turbo such as the disco potato if you are chasing big power.
    Just testing the fit with it on the factory lean. Basically don't bother just plan on standing it upright.
    For the clearance at the back of the head there is a breather tube that you will need to remove and get a fitting welded on.
    There is also the huge water block thing you will need to sort out
    Once these are sorted the oil pressure switch is the next thing that sticks out the most and this can be relocated if you put in a 90 degree fitting and a bit of pipe/hose.
    So buy it
    May 2009
    New South Wales
    awww teaser pics.....
    just because i have 12 months to wait until i can have it in the ta22, so harsh
    haha
    anyways, been tossing round another possibility than the one on ebay
    ebay one = 147,000 k's (cheap ass price, but probly needs a rebuild in the not to distant future)
    threw together a prices (pistons, bearings, gaskets/seals, and a metal head gasket) prices blew out to 2 grand, and thats not even looking at the turbo or any other work that cant be done by myself
    got in contact with an importer who can supply me a caldina halfcut for 3.9 g's on a special order with around 50,000 k's (a few months waiting period, but i have time so no biggy) cost v rebuild suddenly looks appealling
    decisions decisions decisions
    af300e, are you saying that i cannot use the stock turbo, even though i will be getting a custom exhaust manifold knocked up? my intentions for power are not that huge that im wanting to source an aftermarket turbo (thinking 14-15 psi and will be happy with the numbers that gives me)
    the sump will most likely be a 2S modified one, as this seems to work for most ppl
    havent worked out clutch yet, will be a w57 or w58 if i can find one, with a 4y bellhousing, so will have to find a clutch/flywheel combo that will fit without much modification
    jfallen, the gen4 has a remote oil filter?? awesome!! can take that off the list
    thnx again for the info guys, much appreciated
    Joel
    Tasmania
    correct you cant use the stock turbo as the manifold and exhaust housing of the turbo are cast in a single peice and in RWD format the turbo and inlet manifold will both point toward the firewall.
    You could get a gen3 turbo, ive personally seen these push over 200 kw at all 4 wheels (on mine).
    but since you need to make a mani and stuff anyway you may as well get a garrett gt2860 or something similarly responsive but with ultimatly more power potential.
    back to your low km engine vs rebuild toss up at least if you went the higher km and rebuilt it you KNOW for sure that its micky mouse and will be good for BIG POWAS for many kms to come, where as with a low km engine its still second hand at the end of the day.
    EDIT: looks like this.
    1973 TA22
    Don't go for a 2S sump if going Gen 3 and above, the Gen 3 and above engines have a completely different design and your much better off just modifying that.
    Standard clutch and flywheel is a straight boltup to the W5#, but you need to space the starter out by about 10mm, machine the bellhousing, and run a 10mm spigot bearing.
    ([][][]II--LT--II[][][])
    hence my coining of the phrase Turbofold
    I'd go down rebuild road but only as far as rings/bearings/polish crankshaft (if needed,) balance, hone the bores, face block and head, metal head gasket, clean up valve seats and new valve stem seals. On modest power you wont bust a stock Toyota Piston. Only crappy tuners can brake them. Keep in mind though that if you are able to to a compression test or a leak down test and the engine comes up trumps then no point wasting cash on a rebuild. The Caldina motor should pull 180PSI on a compression test (well that's what mine does on all four and it gets 9.5l/100kms on the highway after 70,000kms.)
    Jordan
    May 2009
    New South Wales
    so it sounds like the rebuild is going to be the way to go...
    i suppose i wont really know until i bite the bullet, snatch it before someone else does, and see what kind of nick its in
    and cuts, that "turbofold" pic explains the issue 100%... thnx
    what kind of diameter difference are we talking when getting the cylinder bores honed? enought to require slightly larger than stock rings?
    would be cheering if it wasnt necessary for new pistons, the expensive buggers that they are
    Joel
    May 2009
    New South Wales
    oh, and thnx for that info on the clutch/flywheel and sump TwentyEight
    much appreciated
    (+repping all)
    Joel
  1. 3sgte Limits???
    By Douglas Black in forum Tech and Conversions
    Last Post: 30-11-2013, 11:33 PM
  2. GT-Four ST185 3SGTE Stroker Upgrade
    By =dam0= in forum Tech and Conversions
    Last Post: 14-09-2007, 06:15 PM
  3. 3sgte and 4agze standard weights?
    By Taxi>Maxi in forum Tech and Conversions
    Last Post: 20-03-2006, 07:55 AM
  4. 3sge - 3sgte CAS - interchangable?
    Last Post: 20-12-2005, 09:15 PM
