Results 1 to 15 of 29
Thread: Forums Rules Acceptance
    Default Forums Rules Acceptance
    Guys,
    The board is starting to implement some of the new features of the forum software.
    One of these is the new Forum rules tab up next to the FAQ tab.
    Before you can post again you will need to accept the rules.
    There it a timer at the bottom of the forum rules page that counts down before you can accept. So whilst waiting, you might as well read them.
    Simon
    Beige.... The new Black!!!
    Tasmania
    Default Re: Forums Rules Acceptance
    EDIT: just read, and accepted.... sounds reasonable.
    1973 TA22
    sounds reasonable to me
    I sat there for a while on the 'Dont be a tool one" and thought "is this phisically possible for me to do that
    Z20- SOLD
    Quote Originally Posted by De@No View Post
    Just because you got one doesn't mean you have to be one.
    seeyuzz
    river
    touche'
    your knowlegde overwhelmes me mr river
    Z20- SOLD
    On mine the 180s wasnt 180s. Was more like 720s, given that it went from dummy grid to post first corner in race F1 in the time that it took to run down.
    Great work guys. I read them after realising I actually had to due to the timer and noticed there were a number of things I could brush up regarding my conduct on here. So they have had the desired effect.
    Nath
    -Just Alloy Radiators-
    www.alloyradiators.com.au
    And if you don't brush up, I can force you to read them again..... and again...... and again until you do brush up
    Simon
    In addition to the General forum rules, ther is now a pull down at the top for the specific sections rules. (Classifieds specific, Tech Specific, Cruise and Event specific.)
    This means you will have to sit through the timer in those 3 sections before you can post as well (first time only unless the rules change or users need "reminding")
    Simon
    Ok so i accepted the rules to post in one section of the classifieds
    and now its telling me i have to accept them again to post in another section
    How many times do i have to do this because it is pissing me off!
    i mean, is this really necessary??
    Yeah, It is definatly necessary, But you shouldn't need to sit throught it in 2 different classifieds sections.
    I'll check that.
    Simon
    Should only require it once per section now (ie once for General, Once for classifieds, Once for cruises etc.) that should cover all sections inside of the parent section.
    Thanks for pointing that out.
    Simon
    y0.
    Seeing as the general rules come out with each section can you just put all the rules on one page? Seeing as each sub section is only small anyway?
    Even if you have separate tick boxes for each section and then the submit button at the end?
    (I think if there are any updates for one subsection its not a bad idea to refresh peoples memory on the other rules at the same time, i dont foresee many updates anyway??)
    The general part is the part you agreed to when you signed up so needs to be separated.
    The other areas are broken out for ease of linking to later, and the future roll out of new features kind of needs separation.
    simon
    fair enough.
  1. Forums Clean Up
    By river in forum Forum Troubleshooting & feedback
    Last Post: 27-07-2009, 10:59 AM
