Page 3 of 7 FirstFirst 12345 ... LastLast
Results 31 to 45 of 99
Thread: Operation "1jz" it begins.. 56k warning..
    Junior Member Grease Monkey BEVANI's Avatar
    Apr 2008
    Default Re: Operation "1jz" it begins.. 56k warning..
    ok... from where ???? lol
    Junior Member Backyard Mechanic bigmat's Avatar
    sa
    bunnings sells it. powder form. where gloves and keep away from skin. rinse with vinegar after you use then water
    caustic is alkaline
    vinegar is acidic
    so they will neutral out each other and flush with water
    cheers mat
    sa
    should mention warm up the piece your going to caustic first fairly warm oven or bbq to get best results and leave caustic on for 5-10 min before scrubbing of
    mat
    Apr 2008
    ok so i got the sump clean wit a bit of oven cleaner and some heavy elbow grease.. then i remembered the oil pickup didnt look so good so out wit the grinder to have a look inside..
    its not pretty..
    nehoo i had the old mid sump pickup and it was in perfect condition so out with the grinder again and enter the mig..
    it doesnt look that good but its sealed and is gonna do the job... beats payin 80 bucks for a new one
    Apr 2008
    ok so im a lil stuck on the whole fuel side of things.... im going to run a external fuel pump.. but wat size?(lph) do i need aftermarket fuel pressure reg? rising rate fuel pressure reg?... *anything i have missed* what options do i have and what will suit it best?
    bevani
    Jan 2009
    i think there was talk of a bosch 044 or something like that, im not sure... my car apparently has one, but could also be a fakey (was bought from ebay)
    also id like to know what you're planning in the way of car audio... pm me if you dont want to post it here... if you're getting some pods fabbed, im interested!
    Quote Originally Posted by rdorman View Post
    Car has a walbro not a bosch
  8. #38
    Apr 2008
    im building full custom boot setup 2x alpine 12in wit alpine mono block amp, fusion cap, rockford forsgate 6in 2way in the rear and alpine type E components up front, jvc head deck(mp3 dvd etc) and 7 in monitor.... i fab everything myself... im in the middle of building the sub box(fibreglass) and everything in between but since i started on the 1j conversion that has come to a halt(for now) but just to give you a peek of where im up to there is this...
    more has been done but its the only photo i got atm enjoy
  9. #39
    Apr 2008
    so back on topic... can anyone tell me wtf this is? i know it is related to the heating/cooling side of things but what does it actually do??? im not running aircon in this car only the heating for the winter months so i need to know if i have to keep it or can i scrap it and just bypass it
    cheeers
    bevani
  10. #40
    Apr 2008
    a picture would help hey
  11. #41
    Thats the heater valve, you need that for the heater.
  12. #42
    Apr 2008
    sweet, that solves that problem.
    good news is my engine mounts ive been waiting on(wilbo style) arrive either today or tomoro so il be throwing the motor into its new home for the first time this weekend. ill take happy snaps as i go and see what problems arise from there.
  13. #43
    Apr 2008
    GRRR.... engine mounts got pushed backa week due to short staff at the fabricators... not happy jan.... but i scored a flywheel off one of my mechanic mates 200bucks + fully machined... win... execpt for the engine mounts... pita lol
    i suffer from A.D.O.S... attention deffi... OH LOOK SHINY!
  14. #44
    Jan 2009
    Quote Originally Posted by BEVANI View Post
    [IMGImage007.jpg[/IMG]
    [IMGsidesub.jpg[/IMG]
    thats heaps sweet, pretty much exactly what i want to do, but i want my sub to be behind the seat, and and amp under the false floor.
    do you have a plan for the size of the piece of mdf you cut out, including curves?mine was just trial and error, and i screwed it. going to use the wood for the pods now
    so far ive got an alpine 9882Ri, jaycar 4x100w amp, orion hcca 6.5" splits, and a couple of sub choices...
  15. #45
    Apr 2008
    i actually used the carpet out of the boot... layed it out over the mdf and drew a line around it... take into consideration that it will be different in design as the false floor come up higher in the boot
    back to the build...
    these puppies finally arrived today... 200 bucks, local built.... wilbo style... win
    saturday... first test fit of the engine... pics to come!
  1. Alternator Warning Light Wiring
    Last Post: 04-01-2006, 10:32 PM
