Results 1 to 15 of 29
Thread: massive hesitation when accelerating.
    Western Aus
    Default massive hesitation when accelerating.
    hey all, this is on my sierra but same diff.
    i go to take off, or floor it (while already moving) and the car will bog down, and i mean bog down, to the point of where it will nearly stall.
    then, it'll pick up a bit, and struggle cough and splutter, till i floor it, and it picks up its revs, then goes like the clappers.
    if i then slow down, then speed up suddenly, it doesnt bog, however if i slow down, then cruise along at that same speed, then floor it, it will bog.
    frankly im at a loss as to what it is, and its been getting progressively worse.
    it nearly killed me today when i bogged down, turning onto a road, with a semi coming the other way.
    motor is a fresh reco, as is carbie, however parts of the carby arent new, as the carby i bought was a newer model, and a few things needed to be swapped onto mine to make it work.
    its alot worse when its cold (it will actually stall) and when warm its usually bearable.
    any ideas?
    it was fine, ive changed nothing, and it started, then got alot worse, so its not my tinkering.
    accel pump or somesuch poop?
    Mar 2008
    inner west syd now!
    Default Re: massive hesitation when accelerating.
    sounds like overfueling!
    as you cruise, it floods the carby, once you open it up, it skulls petrol(bogging), slowly it returns to a stoichometric mixture, as the carby empties its over-filled chamber(forgot the word) it starts to make power thus goin hard. Then wen you start cruising again, it starts flooding slowly, and thus the cycle continues!
    Just like tuning a 2-stroker nitro motor!!
    or maybe im just talking crap! maybe the seat and needle seals, since it was reco'd! Jets too big on new carby!
    hope that helps ya a bit!
    wog
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    Its deff a Fuel issue.
    Iam thinking over fueling as stated above. Maybe the wrong needle has been fitted. But it cant be as it has been a progressive issue. Geeze You got a sneaky gremlin.
    Does it have the old Wax choke like the 22y engines.
    when cold, fuel drops out of the air stream and the mixture goes leaner.
    if your problem is worse when cold, then it is running lean... methinks.
    can you richen up the idle jet a turn and see if it has any effect?
    didn7t happen to reseal the carby using silicon at all?
    Mar 2008
    inner west syd now!
    Doesnt bogging down usually indicate rich mixtures though?
    Mar 2008
    inner west syd now!
    bad seals somewhere, would xplain the progression! fuel degrades the seals, get worse and worse over time, thus running more like cr#p!
    you have an interesting issue i must say!
    also could be the float is sticking or the bowl is over-fueling or not filling enough..
    if the plugs indicate a lean mix, it could be a failing fuel pump?
    Quote Originally Posted by woggin
    it can be either rich or lean.
    if it is rich and worse when cold, what do you think is causing it?
    could be choke...
    could just be an incorrectly assembled carby
    Mar 2008
    inner west syd now!
    Oh yea, forgot they had chokes! maybe i should just stick to efi!
    Tallahassee, FL USofA
    Sounds like the acc. pump or a secondary barrel opening up too soon, or the choke swinging closed
    Does it help or hurt if the throttle is pumped when this is happening?
    Look in the carb, twist the throttle, see & hear a jet of fuel from the acc. pump of about 2cc. On many there isn't even a need to remove the air cleaner because it's loud enough to hear.
    Check plugs to see if they are fouled or not. Dark black plugs indicate running rich. May help you in some way.
    Mr Shabadoo.
    Daily JZX100
    Western Aus
    carby is a few weeks old, and i only ever run premium 98.
    ill rip apart the carb tomorrow and check if anything is out of whack, but i just dont know what im looking at, or for.
    May 2006
    tas
    try running 95.. it may actually run better if its currently rich
    when you drop the boot on her it may just be dumping a heap of fuel in it, does it bog down if you progressively apply throttle before opening it all the way?
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Jun 2008
    Taranaki
    Exact same problem with my 5k. My technical diagnosis was 'its farked and needs a repower' but the above suggestions are far more concise.
    1985 KP60 Starlet - Sold
    1978 KE35 SR
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    or you have really bad gap on your plugs, i had this in my 3sfe ST184, replaced the plugs and it was fine after that but yeah
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
  1. Massive vibration/shaking after supra gearbox swap
    By DrNick in forum Tech and Conversions
    Last Post: 28-04-2009, 06:22 PM
  2. 1JZ hesitation
    By Buttocks in forum Tech and Conversions
    Last Post: 28-11-2006, 01:50 AM
  3. Massive sudden Lean-out RB20DET
    By Rex_Kelway in forum Tech and Conversions
    Last Post: 10-11-2006, 01:46 AM
  4. MASSIVE Toyota Cruise Feb 12th
    By chris davey in forum Queensland Events
    Last Post: 16-02-2006, 06:05 PM
