Results 1 to 14 of 14
Thread: 7MGTE flywheel options - suggestions wanted.
    Forum Contributor Domestic Engineer
    Default 7MGTE flywheel options - suggestions wanted.
    I will be sourcing a new flywheel in the next few months for my rebuilt bottom end. Who out there has aftermarket flywheels, what brand, how many $$ and what are your impressions.
    At the moment, I'm looking at xtreme crome moly one, weighing about 8KGs, for around the $400 to $450 mark.
    I realise that there are lighter ones out there, but I'm also led to believe that with such a heavy car, and the low revs used by the 7M, a lighter flywheel will not be as benificial as a smaller engine / car, higher rev combo. Any thoughts?
    Combo is MA71, 7MGTE, R154, currently with 300RWHP, and with more fuel and upping boost out of highflow on new motor, goal is somewhere around the 320 to 350RWHP mark, with as much torque as I can get.
    Thanks everyone.
    Default Re: 7MGTE flywheel options - suggestions wanted.
    choose what clutch you want first, as some of them need a specific flywheel...
    lighter flywheel will always reduce the apparent weight of the car in 1st and 2nd most... but will make it a little harder to slip off the line..
    8kg is still prettyheavy.. what is a stock one?
    From what I can gather from the 'interweb experts', I think they are somewhere around 9.5kg.
    My current clutch is just a heavy duty pressure plate, with full face organic disk. I am quite happy with this, as I'm not into 6000rpm clutch dumps, and not using huge power. Its easily tractable, and holds well even after a few hard laps at winton.
    I'm not sure whether I'll reuse this current clutch setup as it only has about 20k on it, or whether to change disks to something slightly bitier whilst keeping the same pressure plate, or change the whole setup. Yet to be determined.
    I'm pretty sure that I won't need to be getting into the multiplate setups.
    Anyone????
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Got a second hand cro-moly flywheel here for the 7MGTE that weighs in at 6kg
    Bazooka: Pm'd.
    Anyone else have any thoughts or experience? Surely someone with a 7M has changed a flywheel?
    Australian Capital Territory
    I got an XTD chrome moly on in mine. It rev's quicker, highly recommend getting a fairly light one.
    TRD for xJZ is ~6kg (I weighed). And they claim that it is 24% lighter than stock.
    I'd expect xJZ and 7MGTE flywheels to be pretty similar (Bar bolt pattern) as they run the same clutch factory.
    http://www.trdparts.jp/english/parts_flywheel.html
    Wilbo's JZA80
    Wilbo's JZZ12
    OS Giken comes in around 7kg if i remember correctly, comes with bonus twin plate too !
    Quote Originally Posted by BlackSupra
    Details? I can't find a listing for any M series motor.
    Quote Originally Posted by SlimLim
    Details?
    Thanks for the input so far to everyone.
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    talk to allan
    he has alloy flywheel and twinplate for 7m atm
    Quote Originally Posted by boxh34d
    Details?
    TS2BD = 400hp
    or TS2CD = 600hp
    Otomoto should have them.
    Mines a cheapie from US ebay. Supramania gives XTD a bad rep for misleading people on their clutches, but i have no problem with their flywheel.
    Thanks to all that have replied thus far.
    It is appreciated.
  1. 4AGZE 212mm vs 200mm flywheel
    By craigy in forum Tech and Conversions
    Last Post: 22-12-2005, 10:55 AM
