Results 1 to 11 of 11
Thread: JZS171 into mx83 NEED HELP!
    Nov 2013
    Default JZS171 into mx83 NEED HELP!
    Hi , all first post so give me a break
    i have a s2 mx83 and converted to a jzs171 1jz +auto. all is done apart from wiring and installing the thermos.
    so basicallyim situated in Dubbo NSW and having alot of trouble finding anyone to wire this if there is anyone on here that can point me in the direction of someone out here of relatively close that would be able to wire this would be much appreciated , i havent attempted because wiring gives me more then just a headache .thanks in advance
    Nov 2011
    Default Re: JZS171 into mx83 NEED HELP!
    I can do it but it will cost abit to travel out there
    if u can get the car to Sydney next week I can do it abit cheaper
    as im going down there next week
    Nov 2013
    thanks mate , im really trying to steer clear of actually taking the car down to sydney or anywhere just because of the hassel , as i do have peoplethat could do it down there im just really after someone out here so i dont have to travel . thanks a heap for the offer though
    Nov 2011
    for 2 grand ill drive do you from qld hehehe
    Nov 2013
    haha ud have to ride a bmx for it to be worth 2 grand lol
    what do i need just to get it to start ? like what pins ect?
    Nov 2011
    just download the wiring diagram and read thru it
    or u can send me your looms and I can wire it up
    its not a 5 minute job
    the other big prick of a job is your ecu is in engine bay and Cressida is behind dash
    so making it neat is a pain or you can extend the engine loom and fit ecu under dash
    u need to power ecu
    power coils
    power injectors
    and fuel pump
    just run them all to a big switch like most on here do
    and then the starter and alternator and it should start
    I sent him the wiring diagrams for the JZS171
    Here are the colours of the wires and their functions on my MX83 GRANDE loom plugs from 7MGE motor to underdash plugs
    White plug
    yellow with brown spots___________ speedo speed sensor
    brown _________________________ speedo speed sensor [make sure you earth this one]
    yellow_________________________ temp sensor
    black__________________________ tacho
    yellow/blue _____________________ oil pressure switch
    red/green [2] __________________ reverse
    green__________________________ park
    red ___________________________ neutral
    blue___________________________ drive
    light green______________________ 2
    pink __________________________ L
    Square grey plug
    small black/white _______________ AC clutch
    blue/red_______________________ FP diags
    black/red _____________________ +B diags
    red/black _____________________ 12v supply for speed sensor etc
    big black______________________ nsw
    big black/white _______________ nsw from start relay
    light green ____________________ goes to purple/white in other grey plug
    green with spots _______________ tccs diode
    green/white ___________________ stop light switch
    big black/yellow________________ power from ignition
    small black/yellow _____________ solenoid 2 in transmission to cruise control ecu
    green________________________ from airflow for circuit opening relay
    black _______________________ from temp sensor on water inlet to start injector
    Rectangular grey plug
    pink__________ _______________ TE1 diags
    brown/black __________________ earth
    pink/green__________ _________ TE2 diags
    grey________________________ VF1 diags
    purple/white__________________ goes to pink. and light green in other grey plug
    grey/green___________________ brown wire on abs sensor
    pink/blue ____________________ grey wire on abs sensor
    purple ______________________ blue wire on abs sensor
    Jealousy is a curse
    Nov 2013
    thanks guys , im more then likely just not seeinging it they way it is , ill take a break from it and go again
    Nov 2011
    u need to make drawings of your plugs near the ecu
    both for cressdia and 1jz
    otherwise u will never understand
    what madmont has described above is fine if u know what Toyota symbols mean and plug layout
    if you do these day in day out but looking at diagrams is useless unless u know where the wire is
    I did a jzs171 in a supra afew months ago
    took me awhile cause I lengthend the loom so ecu sits under dash
    I need to charge that much because I have to ask the wife to take a day off from our xmas holdays to drive to dubbo wire your car and drive back all in a day then 2 days after then drive back home to qld
    Quote Originally Posted by dumbass View Post
    Could be a problem finding room for the ECU box under the bonnet of the MX83
    May have to relocate the battery as I did for my Hilux if ECU was left under bonnet
    See picture to left. ECU is in bottom right of picture where battery used to be
    Battery now where the air cleaner used to be with a Suzuki air cleaner behind it
    Jealousy is a curse
    Nov 2011
    yes I was lucky I had plugs and about a foot of wire on them from a vvti 1uz so u lengthened all wires
    took half a day just to lengthen all wire properly but it looked much better
  1. 1JZ-GTE [JZX110/JZS171] MAF issue
    By George in forum Tech and Conversions
    Last Post: 08-07-2016, 08:33 AM
  2. 1JZ-GTE from JZS171 Crown wiring diagram?
    Last Post: 19-10-2015, 01:56 PM
  3. JZS171 into Series 2 Mx83 - Mount Requirements
    By BLK_20v in forum Tech and Conversions
    Last Post: 14-10-2012, 10:09 PM
