Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 143
Thread: HSD coilover sleeve kits 45mm 48mm 51mm 55mm now available only $299
  1. #61
    Default Re: HSD coilover sleeve kits only $299
    Hi Grant,
    I'm about to place an order through your website for a coilover kit but just had one question and thought it might be relevant to others, what ID are the springs with these kits?
    Shane.
    First post...
    Quote Originally Posted by dori dori
    Available in 48mm and 51mm internal diameter...
    ([][][]II--LT--II[][][])
  2. #62
    Junior Member Domestic Engineer dfunkt's Avatar
    Apr 2007
    is that the sleeve diameter, or the spring diameter Simon?
    Owner of the Big Red Whale
    "i cant eat this because its too spicy" "i cant eat that because it has green stuff in it" "i cant eat that because its chilli soup with Blair's Ultra Death Sauce in it"... winge winge winge...
  3. #63
    Quote Originally Posted by twentyEight
    First post...
    Nah that is the sleeve ID, I said spring
    I have ordered the 51mm sleeve ID but I am wondering about the spring ID as I'd like to throw the springs on another set of struts while I build the new struts so I can test the spring rate and either settle on that or order more in a different rate
    My KE25 thread
  4. #64
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Hi Shane, the spring ID is 65mm.
    Hi Grant,
    Shane.
  5. #65
    Thanks Grant, that's perfect for what I plan to do.
    I look forward to seeing all the gear when it arrives
    Thanks again.
    My KE25 thread
  6. #66
    Ah crap... That'll learn me!
  7. #67
    Are there higher rate springs available seperately? I noticed that you do a good range of spring weights for the HSD coilovers...
    -RM.
  8. #68
    Hi Mullett, yes alternate spring rates are available. They retail for $100 per pair.
    We stock 3kg through to 18kg in 200mm and also 175mm free lengths.
    Fitted these up over the weekend, and the sleeves are a perfect fit for celica struts. Not sloppy like some are known to be.
    Seems to drive really nicely... not that I have much to compare them too
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
  10. #70
    Thanks Grant for the prompt service, received my 2 sleeve sets plus extra springs. Top work!
    Phil
  11. #71
    Good to hear Tim.
    Throw up some pics of the finished product when you can.
    Quote Originally Posted by timbosaurus
  12. #72
    Hi Phil, good to hear.
    Quote Originally Posted by 1JZ-Rolla
    Phil
  13. #73
    Next day delivery on my coil over kit and steering wheel, all looks great too.
    I'll post a pic of the steering wheel installed once I reassemble my dash and the coilovers once they are complete
    My KE25 thread
  14. #74
    My coil over kit is excellent. Here is a couple of pics.
    Now - RA23-WRX
  15. #75
    Jun 2007
    Are their any problems with using this kit on ae86 struts aswell as using T3 cambertops?
  1. Coilover sleeve and strut welding info needed
    Last Post: 02-09-2012, 08:57 AM
  2. Thoughts on sleeve coilover kits (MA61)
    By VA61DETT in forum Tech and Conversions
    Last Post: 18-12-2008, 05:55 PM
  3. Coilover sleeve kits, what's the go?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 27-07-2008, 09:36 PM
  4. coilover sleeve lenght?
    By slide86 in forum Tech and Conversions
    Last Post: 18-01-2006, 06:18 AM
