Page 8 of 10 FirstFirst ... 678910 LastLast
Results 106 to 120 of 143
Thread: HSD coilover sleeve kits 45mm 48mm 51mm 55mm now available only $299
  1. #106
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Default Re: HSD coilover sleeve kits 45mm 48mm 51mm 55mm now available only $299
    Hi guys, due to the popularity of our HSD coilover sleeve kits, we've expanded the range to include two new sizes.
    They are 45mm and 55mm.
    The default spring rates are as follows:
    45mm - 4kg
    48mm - 4kg & 5kg
    51mm - 4kg
    55mm - 6kg Note: due to the size of the sleeve this is the only spring rate we currently have in stock. Different rates are available to order only. Here is an image of the 55mm kit.
    Customers can choose an alternate spring rate at no additional charge (stock permitting)
    Custom ****** 1st year Apprentice
    Nov 2008
    What is the best way to coat these so they don't rust???
    JZA80 Supra Aerotop undergoing 3UZFE VVTi + Twin Turbos / Getrag 6 Speed conversion
  3. #108
    Machined steel is always going to rust. In racing the guys coat things in wd40 pretty regularly to keep the rust away.
    Now - RA23-WRX
  4. #109
    cheers SlverRA23.
    Its best to paint over the welded area and WD40 or similar regularly.
    Sep 2009
    Hi
    If you are putting something like this together with steel sleeves and alloy nuts you really should use some antiseize and that will stop the corrosion and stop the alloy galling on the steel thread. Its not like you adjust them much once installed. If you adjust them you really need a wheel alignment every time.
    Corey
  6. #111
    all good advice.
    Jul 2009
    Quote Originally Posted by cyberdiamond View Post
    I wrapped the threads on mine in duct tape.
  8. #113
    If only there was a suitable lubricant that doesn't attract dust & dirt
    What about "dri-glide" or a similar teflon based spray product?
  9. #114
    what about graphite lubricant?
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  10. #115
    In what form? I've only seen graphite grease or powder. Are there other commercially available forms?
  11. #116
    What about a wax based lubricant that is in a liquid suspension, apply wet and when it dries you're left with a dry wax protection that won't attract dirt. Wouldn't need reapplication for a long time either.
    My KE25 thread
  12. #117
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    you know a little too much about lubricants and attracting dirt
    Quote Originally Posted by YLD-16L View Post
  13. #118
    Heh, i was thinking what about chian lube. The dry wax type.
  14. #119
    Just heat the sleeves and dip in ATF so they turn purple before welding your sleeves on .
  15. #120
    Thanx Grant...
    ...another happy customer. Ordered yesterday, delivered today
    I'll be sure to get some pics up, when they're fitted
    Dav Hoban
    Board Member
  1. Coilover sleeve and strut welding info needed
    Last Post: 02-09-2012, 09:57 AM
  2. Thoughts on sleeve coilover kits (MA61)
    By VA61DETT in forum Tech and Conversions
    Last Post: 18-12-2008, 06:55 PM
  3. Coilover sleeve kits, what's the go?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 27-07-2008, 10:36 PM
  4. coilover sleeve lenght?
    By slide86 in forum Tech and Conversions
    Last Post: 18-01-2006, 07:18 AM
