Results 1 to 6 of 6
Thread: 1jz HKS camshaft / Valve train noise
    Jun 2008
    Default 1jz HKS camshaft / Valve train noise
    Ok guys, I have a question regarding valve train noise.
    I had my 1jz head ported and polished at the same time I got Brian Crower springs & Ti retainers along with HKS 264's(they were shimmed). Now I'm wondering if any others out there can comment on Valve train noise with larger cams and stronger springs. The OEM valve train is hardly audible, my new setup is quite noisy. Is it normal? or should I get the clearances checked?
    Current Builds
    Soarer Built 1.5jz 425rwkws
    1JZ LPG Build, so far 204rwkw@10psi
    Default Re: 1jz HKS camshaft / Valve train noise
    Yep, i bought kyle's (6boost) motor which had some rather large custom cams in it, sounded like it had a 6/71 strapped to it.
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    i haven't got experience with OHC, but when i went from stock 8mm lift cam to 285deg 11mm lift cam (and fixed the rocker geometry), valve train got quieter
    maybe it is an OHC thing
    can't hurt to check clearances, but the stronger springs may make any noise issues worse.. as long as it doesn't sound like it is hurting... and doesn't chew out the cam or buckets/shims
    Melbourne Victoria
    the cams and head shouldnt be shimmed up ,until the head is bolted to the block as the clearences can and will change with a 264 profile it would be 10 on the inlet and 12 for the exhaust so check the base circle and see what you have when its cold
    Jun 2008
    Shit Jordan, r u still after a Shift Kit mate? If so I have one ready, just need some where to do it, My mate won't be at the workshop until the 21st and my Misses is due with number 2 on the 26th.
    Current Builds
    Tallahassee, FL USofA
    Does it sound like it is only just a few that are making excessive noise, or all 8 12 16 20 24 whatever that sound roughly equal? Either way, they should always be checked on every engine!!
    Quote Originally Posted by 131OWN
    Yes, this shouldn't be any sort of a question or post at all, until the lash/gap/clearances are checked.
  2. 4AGE valve issue
    By stahlz_ae86 in forum Tech and Conversions
    Last Post: 11-05-2006, 06:26 PM
  3. Injector rail noise on 1UZ.
    By MacroP in forum Tech and Conversions
    Last Post: 06-05-2006, 09:47 PM
  4. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 10:20 PM
