Results 1 to 14 of 14
Thread: 1JZ sump variations into RA28 with KE70 rack and pinion
    backyard mechanic Grease Monkey celica77's Avatar
    QLd
    Default 1JZ sump variations into RA28 with KE70 rack and pinion
    hey guys,
    building up a ra28 with 1JZ conversion and ke70 Rack and pinion steering. just need some help with the 1JZ engine variations, and there sump set ups. from what ive gathered so far i need to run a front sump version.
    i would love to use a VVTI version, and the latest year model possible.
    can someone tell me what model and year will be best for this.
    cheers guys
    Default Re: 1JZ sump variations into RA28 with KE70 rack and pinion
    jordan76 has just finished his 1jz vvti into a ra23, suggest you talk to him, hes also in qld
    RA23 - Twincharged
    JZZ20 - Daily
    You'll need a chaser motor or half cut. Take your pick jzx81, jzx90 or jzx100. The jzx100 motor is the vvti single turbo version.
    The soarer and supra motors were all mid sump.
    stidnam
    Front sumps kits are usually $250 if you ended up with a mid sump half cut. Does a non vvti 1jz sump and pan fit the vvti versions?
    all 1jz bottom ends are the same, though the vvti version runs 9.0:1 compression. only difference i believe
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    QLd
    thanks guys. if all the sumps are interchangeable i will just get the most recent 1JZ VVTI i can and get a front sump for it.
    also one last question what car is the R154 gearbox off originally? and what are they on? is this the standard manual 1J gearbox?
    Jun 2006
    Tasmania
    Standard 1jz manual box out of
    jza70 supra
    jzz30 soarer?
    jzx90
    jzx100
    Probably more
    The R154 was used behind turboed engines.
    in addition to 1jz it was also used behind turboed 7m's
    SSS will put what ever sump you want on the motor they have for the same price....just so you know.....aslong as they have that sump instock aswell.......
    Junior Member Grease Monkey ra28_miles's Avatar
    Mar 2009
    W.A.
    i'm going through this right now. I thought i would have to go with a w58 gear box behind the 1jz cause a R154 box would not fit in the trans tunnel of a RA28 celica. Well thats why i thought sheepers went for a w55. Turns out after reading 77GZE thread, a R154 WILL fit a ra28 trans tunnel, with modification to the firewall to clear the flywheel housing, i.e. smashing it out with a hammer.
    For the price of a W58 and a adaptor kit (flywheel, bellhousing, clutch, etc) to fit the 1jz i could have brought a R154.
    Yup and you still have to bash the crap out of the opening of the trans tunnel anyway with the w58 because of the bellhousing!
    stidnam
    Mar 2009
    W.A.
    yeah, but not as much as you'd think, only took an hour. I thought the r154 was going to be too wide more than any think. That was my main concern.
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    Quote Originally Posted by Jordan 76 View Post
    The conrods are different aswell, I presume that the pistons are different also for the different compression ratio.
    The latest version of the 1JZ VVTi would be in the 2004 JZX110.
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
    If you are fitting an R154 to an RA28 you will need to *massage* the tunnel for its entire length down to near the shifter where the box goes skinny again. Unless ofcourse you have mounted your engine hanging of the front of the car and the box hanging below the sills.
  1. TA22 + rack and pinion
    By "Z" UTE in forum Tech and Conversions
    Last Post: 19-05-2017, 11:02 AM
  2. RA23/28 with KE70 steering column and rack and pinion
    Last Post: 24-01-2017, 03:39 PM
  3. KE70 box to rack and pinion bracket
    Last Post: 25-11-2007, 08:11 PM
  4. AE86 "Cusco" quick steering racks??
    Last Post: 02-06-2007, 12:13 AM
