Could try runnin some Nulon or similar Additive in there and see if that quietens it any ?
hey guys,
Diff in my ma61 has been noisy for a while and im looking into replacements/rebuilding.
The noise: Loud whirring noise would say higher pitched, loudest at 100kmh above 120 almost silent and its pretty quite below 80 ish. Only when its accelerating. As in if i sit on 100 and i accelerate its noisy back off noise is gone. From the research ive done it seems to be the pinion/crownwheel is worn. Its a bit clunky too but that part doesnt bother me just the dam noise.
What im wondering is, is that bearing or pinion noise?
If its pinion/crownwheel noise and i rebuild the diff with a trutrack center then the noise will still be there correct?
Thanks for you time, bit of noob when it comes to diffs
nath
11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
Still going good
http://www.youtube.com/watch?v=tc_7aRUGshw
its hella noisey no addative is going to help ive accepted this diff is toast (still locks up lsd most times though)
If you re-use your existing CP, yep! Bearings should all be changed when going to a new centre, so if it's bearings that should be no issueOriginally Posted by naten
thought as much dam you greg you should of sold me your diff
