From what I've heard the ST184 celica AFM is compatible. You'll need a fuel/air adjuster to get your fuel ratios back, but you need some fuel control anyway if you're upping the boost, mine's running at 10.2:1 under boost...
RM.
just need to know if the 4agze afm (aw11 mr2 s/c) is the same or compatable with any commonly available afm?
RM.
an ST162 one is pretty much spot on, the a\f ratios are pretty close to the gze one
my old gze used one of these and it was the same as my current standard gze in terms of fuelling. the only thing is the st162 one has 3" outlet instead of 2.5" so you'll need to adjust the pipework a little
89' MR2 AW11... His
00' MR2 ZZW30... Hers
