Page 4 of 13 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 192
Thread: 3VZ-FE into st184 5th gen celica.... now running....yippeee
  1. #46
    Junior Member Backyard Mechanic Jaemus's Avatar
    Default Re: engine swap......3VZ-FE into st184 5th gen celica
    fair enough
    yeah work out that boost cos i think youll find itll be quite low with that pulley
    also youre gonna need alot more belt on that pulley i think man... AW11 owners with that SC14 have it slipping with 60-70% belt coverage at 12psi
    1992 MR2 GT turbo
    2009 Lexus IS-F
    Built Australia's first V6 MR2 >> Winner: "I'd Drive It" award - Toyfest '07
  2. #47
    Quote Originally Posted by fibrewizard
    got a few issues with the supercharger.... that are easily solved but just a pain.......
    1st....stock SC14 clutched pulley contacts chassis rail.....so non-clutched pulley is the answer......
    also due to not being able to make mounting whilst motor was in the celica we got bottom radiotor mount that charger aslo contacts..... this will be solved by moving radiator mounts and leaning radiator forward at the bottom about 5mm but going an inch to be sure........
    also does anyone know the stock harmonic balancer size in mm for the 1ggze.... just so i can work out boost.....
    Yeah, my MR2 belt needed to be pretty tight. I was running 12psi with a 165mm pulley on a 4A-GE, so you're going to need to run at least that ratio (from memory std SC14 pulley is 125mm, giving a ratio of 1.32:1) to get any kind of boost on a 3ltr.
    Ideally if you're getting a solid pulley made, get it made smaller, rather than a bigger crank pulley (unless you can have a dedicated belt for the SC, because otherwise you'll over-spin your alternator) but keep in mind that if you go too small you'll have trouble getting the belt to grip.
    Nick had a 185mm pulley on his for a while, giving a ratio of nearly 1.5:1, which worked really well, but i think it started to run out of puff around 5500-6000rpm. If you're only going to spin to that speed, then a ratio of 1.5:1 is probably ok.
    That said, you're going to want good belt coverage, and ideally I'd still go for a dedicated belt, because if you put too much tension on the belt for the alternator you'll kill the bearings, but the SC14 has a pretty solid bearing inside and can handle a bit more tension.
    -RM.
  3. #48
    always looking like a Grease Monkey fibrewizard's Avatar
    Clutch on left is my exedy for the celica..... right is clutch from 3vz had exedy clutch plate
    E153 camry 5speed gearbox
    celica 5speed E53
    out with the old and tired 5sfe
    in with the new......used 3VZ-FE
    2012 GT86
    V6 powered 5th gen celica. Sadly moved on to build below
    91 st185 aus delivered, V6 turb project,
    2015 Kun26r hilux
  4. #49
    2012 GT86
    2015 Kun26r hilux
  5. #50
    Default Re: supercharged 3VZ-FE into st184 5th gen celica
    more updates....
    nice project, so did you end up using the camry struts etc? (i assume not since you ended up going back with the std gearbox)
    so then do you just do a gt4 brake/disc upgrade?
    how did you modify the engine mounts? got pics?
  6. #51
    Quote Originally Posted by PlacentaJuan
    more updates....
    when push came to shove and i had to make a decision on which box to use i went with the standar as mounts didnt transfer like i was led to believe...... however now i beleive i have found a solution for that......so if std celica box shits itself i still got the option of camry box........
    all my engineer said he wanted to see to pass it was slotted rotors....so for now just going with that......as well as pads to match....
    engine mount is yet to be made heading down there this weekend so planning to make mount, service cv's and reinstall, and hook up all clutch and geabox related cables and hoses..... will see how much i get done......
    2012 GT86
    2015 Kun26r hilux
  7. #52
    80's stylin Domestic Engineer Sammich's Avatar
    May 2007
    whoa...this thing'll be mental lol nice work...
    S/C came out of left field
    but srsly...need to get that kit painted lol
  8. #53
    some more pics........
    radiator literally just turned up so couldnt help but to take some pics and post em up.......
    also pics of slotted rotors.....
    2012 GT86
    2015 Kun26r hilux
  9. #54
    Fear the Rapeodile Carport Converter blakeg's Avatar
    May 2006
    man did you make that grp a bonnet, it just looks weird for some reason
  10. #55
    Junior Member Backyard Mechanic greywolf's Avatar
    Nsw
    Always like watching engine swaps, always wanted to explore an V6 into a GT4 once I get my hands on one. The more the better I say, especially since I wanted to go the 3VZ as well. Either that, or a 3VZ into an SW20. Will be watching this one with interest.
  11. #56
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    Quote Originally Posted by greywolf
    youve seen Jameus's V6 Sw20 right?
    and im watchin this too, like many i wanted to do this but i needed the car goin that day so i just went with a $100 3sfe
    and i think that FWD convert verses a RWD convert would be totaly sweet in a drag, and the toque steer (shudders with excitment and wonder of why i have excitment )
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
  12. #57
    Nsw
    I have read of it yes !!!!
    FWD vs RWD is always a fun contest
  13. #58
    engine mount is made... and in...
    cv's are back in...... the cv centre bearing carrier we modified work a treat....perfect.....
    new aftermarket twin core radiator is in.........now i just need hoses.......
    here a a few pics to keep you all interested.........
    2012 GT86
    2015 Kun26r hilux
  14. #59
    nice work dude, cant wait for startup, interested to see how well that supercharger goes!
    greywolf - when i get the SW back from spraying you are welcome to come around and check it out
    1992 MR2 GT turbo
    2009 Lexus IS-F
  15. #60
    Nsw
    Thanks for the offer Jaemus, I will most certainly take you up on that !
  1. MA70 --> JZA70 Conversion
  2. Celica Ra65 engine swap to 7mge
    By Mk3_supra in forum Tech and Conversions
    Last Post: 18-08-2007, 10:06 PM
  3. Liberty engine swap
    By jimmy_a in forum Tech and Conversions
    Last Post: 05-06-2007, 04:09 PM
