Page 13 of 13 FirstFirst ... 3111213
Results 181 to 191 of 191
Thread: 3VZ-FE into st184 5th gen celica.... now running....yippeee
  1. #181
    always looking like a Grease Monkey fibrewizard's Avatar
    Default Re: 3VZ-FE into st184 5th gen celica.... now running....yippeee
    Quote Originally Posted by greywolf View Post
    What about the mounting of the transmission to the VZ, is it a straight bolt up ? Or will you need to use an adaptor plate ?
    bolt pattern and bellhousing will bolt straight up, the dowles are in correct position but a few of the bolt holes while they line up need threading for the bolt as the bolt will come from the opposite side,
    the transfer case and block will need grinding to allow enough clearence and thats pretty much it.......
    the clutch is identical between the 3vz and the 3sgte, even exedy have them with the same partnumber.....
    so while bolting up has a little bit of messing around, the cluth is identical so will all fit together and work a treat, as long as it can hold on with the turbo v6...........
    i will update my gt4 thread with pics and info as it all happens, so keep an eye out for it,
    86GT manual, Velocity Orange, (awaiting build and delivery)
    V6 powered 5th gen celica.(daily).
    91 st185 aus delivered, V6 turb project, possible 3sgte build??????????
    st204 auto, (wifes daily)
  2. #182
    Junior Member Backyard Mechanic greywolf's Avatar
    Nsw
    Sound brilliant mate, will have to subscribe your gt4 thread now.
  3. #183
    hi guys..........was absolutely great meeting everyone at nationals,
    i was a little shy and quiet, spoot racing guys are great guys,
    good to meet justen, stit, Rona,
    my youtube channel is updated with vids,
    and i am already 1/2 way to preping car for next years khana with suspension upgrades.......
    my first attempt at drag racing in the v6 was definately interesting and a challange with traction, but great fun......
    see you all next year
  4. #184
    ok well i have tried to upload pics of the weekend and new mods to celica, but for some reason uploader is giving me an error,
    so will try again later....
  5. #185
    well well, been such a long time and thanks to [email protected]_man for bringing me back,
    so whats to update on the celica......
    well nearly 2 years on and it is still going strong, no major issues, spun a big end bearing, so rebuilt bottom end, bore and hone, whiteline rear strut brace,
    needs a new paint job, but outside of that it has been the best conversion, it was relatively easy no major drama, and has been loads of fun to drive.....
    need to upgrade the 20+ yr old suspension, and interior,
    though it has been very neglected since I got my brand new gt86 in dec '12
  6. #186
    80's stylin Domestic Engineer
    May 2007
    welcome back mate
    MA61 + 5M-E POWAZ: sold :'( | MX73 + 5M-GE: asploded. RIP :'( | MA61 + 2JZ-GE: 80's radness with 90's power/reliability/economy
    Quote Originally Posted by George View Post
    these wheels are so jap I even want to kill a whale. For strictly scientifical purpose, of course.
  7. #187
    yeah, ditto for the welcome back.
    Just going through the thread to check out how you did the engine mount.
    Doing an engine conversion on my Excel (would love to do a Tiburon V6 with 6 speed box, but they're ridiculously expensive), and have realised how much overkill I was going to go.
  8. #188
    from what I have read from when I had my excel..... the lantra discs are a good swap....... I got a lantra sitting in my yard atm
    mounts don't need to be hectic I just trolled wreckers for something that I could work with and went from there.....
    so as you can see got v6 mazda 6 rear mount, and just bolted up a adapter plate, that way still got strong rubber mount and fits easy enough to remove if needed
  9. #189
    I've already fitted the steering knuckles from the Elantra, which then allowed me to use Mitsubishi FTO Mivec front calipers (or Magna V6 Verada/Mirage RS/EVO III) & EVO III rotors (cos 4 stud, not 5). I need 15" wheels to clear the front brakes.
    FTO/EVO III/Mirage/Proton Satria GTi master cylinder bolts to Excel booster.
    Rear uses Excel hubs still, but Elantra rear rotors (as same as FTO rotors but with centre bore that is correct for Hyundai), calipers & mounting plates off FTO/Mirage RS/Satria GTi & XLi with matching handbrake cables. Just needed a 5mm spacer plate between the caliper & mount.
    The difference between my engine conversion & yours is that the Camry V6 is of a similar length to the S series 4. I'm using a bigger 4 cylinder which is about 20mm longer. So now the mount bolted to the body interferes wth the timing cover, and the cast part bolted to the block is hard up against the chassis rail.
    Luckily, the single cam Excels came with a steel mount, not aluminium, so I can cut it down & weld to it.
    How thick is the different metal parts you uses for the mount?
    I'm thinking just to get a single piece of plate, but get it bent under instead of welding together like you've done & then use 2 of the 3 mounts on the casting, but also connect it to the 2nd mount behind. The plate would be welded to the steel mount with it extended a bit above to get a good fillet weld in, and possibly a gusset underneath.
  10. #190
    sounds like you got it pretty much sorted.....
    my adapter plate, 6mm mild steel running vertical, and 4mm angle for the bottom to meet up with stock mounting bolt holes,
    mazda 6 mount for memory is about 4-5mm thick steel, and that is as you see just bolted to the 6mm vertical
  11. #191
    Got it sorted? Considering the path the car has ended up taking, I wished I'd started with something from a manufacturer that has some decent performance cars
    Mitsubishi & Toyota spring to mind...
  1. MA70 --> JZA70 Conversion
  2. Celica Ra65 engine swap to 7mge
    By Mk3_supra in forum Tech and Conversions
    Last Post: 18-08-2007, 09:06 PM
  3. Liberty engine swap
    By jimmy_a in forum Tech and Conversions
    Last Post: 05-06-2007, 03:09 PM
