Results 1 to 14 of 14
Thread: S series diff centre, can someone measure one?
    Default S series diff centre, can someone measure one?
    Does anyone have an S series diff centre out of car they can quickly measure??
    and if possible, to check the size/splines of S series axles?
    i'm looking for the following measurements
    to compare with these ones (an LSD i have, a 6" and an early T series)
    1- 35mm (6" is 34)(前期T=34or35??)
    2- 134mm (6" is 132)(前期T=144)
    3- 96mm (6" is 95)(前期T=99 or 105??)
    4- 128mm (6" is 116)
    every single AE86 in australia came with an S series diff, so there must be some around
    Default Re: S series diff centre, can someone measure one?
    bump...
    no-one has one they could measure?
    Breaker of all things aka Backyard Mechanic Chrisso's Avatar
    Vancouver, BC
    If I've got time I can do it in the morning. Got one sitting on the garage floor.
    AE86 4 shades of silver - The Lone Ranger's steed is on the road again!
    AE86 shell - waiting for a donor car from the auctions.
    awesome thanks
    just those main dimensions should be enough to identify the LSD i have sitting here
    Nov 2007
    Can measure axle diameter at the splines but i'm 99% sure (I compared some about 12 months ago) that they are the same as the smaller T series axles so it won't help you confirm the identity of yours. I sold the centre.
    I'll measure anyway and post.
    Vancouver, BC
    Drip feed of information. I didn't want to wake the neighbours up hammering the locking tabs down early this morning, so 1 & 4 are:
    1 - 35mm
    2 - 134mm
    3 - ~96mm (I was defeated by a couple of locking tabs, till I find a sharper punch)
    4 - 127mm
    I'll get you the other two tonight when I take the gear off it.
    ooh, thanks muchly! it is looking good so far
    Victoria, Mt Macedon
    I'm 100% that S and small T series axle splines are the same
    Vancouver, BC
    Above post edited for extra measurements.
    I have both sets of axles at home too. I'll get the verniers & camera on those. From memory they look pretty damn similar.
    yah the axles are 24mm and i think (as Hen said) same between S and early T.
    are you 100% on the 35mm for the bearing mount bit? i will remeasure mine tonight
    thanks muchly!
    i wonder why people say there are no series LSD's?
    New Zealand
    Mainly because of all the idiots (at least here in NZ) who try to sell the standard 4 pinion centre as an LSD because they don't know what an LSD centre looks like.
    Callum
    ahh, i see. happens here occasionally too, but they usually put a few ??? after LSD
    i have a part number from TRD catalogue, but the part number on box has been washd off by oil over the years
    Vancouver, BC
    [QUOTE=oldcorollas]are you 100% on the 35mm for the bearing mount bit? i will remeasure mine tonight /QUOTE]
    Remeasured this morning and my dodgy verniers measure 35mm. They're not exactly a precision tool, cost me $2, but the measurement is consistent = good operator
    fantastic! thanks Chrisso!!
    my dodgy $5 veriners (and more importantly, dodgy eyes in poorly lit room ) measured wrong.
    the LM48510-N bearing is suppsed to have an inner diameter of 34.925mm
    WOOHOOO!, i will add extra rep when i can
  1. Hilux Diff Centre - JZA70 Torsen Installation
    By Pure_In_Sanity in forum Tech and Conversions
    Last Post: 05-12-2011, 08:52 AM
