Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: identifying diff centre.. SOLVED!!!!!I is S-series TRD LSD
    Default identifying diff centre.. SOLVED!!!!!I is S-series TRD LSD
    heya guys n gals,
    i have a TRD LSD centre sitting in front of me that i can't identify.
    so far i know the axles should be 23 spline and 24mm and it has an 8 bolt crown
    it is a little bigger than a 6" starlet diff (B? U?), so i'm thinking maybe it is a D, or an S, or an early T perhaps.
    the axles indicate early (zenki) T series, but the other dimensions seem too small?
    for the following measurements, i got (updated with U/6" measurements)
    1- 35mm (6" is 34or35?)(前期T=34or35?) (bearing is LM48510-N)
    2- 134mm (6" is 132)(前期T=144)
    3- 96mm (6" is 95)(前期T=99 or 105??)
    4- 128mm (6" is 116)
    side bearing part number is LM48510-N, outer diameter = 65mm
    edit: it is far too wide to be a U series, but is only slightly bigger diameter.. = S?
    edit: looking up this pretty good Timken bearing catalogue http://www.timken.com/EN-US/products...dOlder7391.pdf
    "SET5" = LM48510 cup = 6" diff and 6.38" diff. nothing else toyota up to 89
    i thought it was said S series LSD's don't exist?
    any help muchly appreciated!!
    New Zealand
    Default Re: Identifying diff centre.. D? S? T?
    Interesting. I am assuming it has TRD stamped on it? It is funny watch people try to sell standard S series 4 pinion centres as LSD's when they clearly aren't, however I doubt you would post without being damn sure its LSD. Got any pics of it? I have never heard of a D series LSD either so will be a rare item either way.
    You say it is bigger than Starlet 6" (U code), I know the B code looks physically smaller than U code so it could be a U code. Or have you got a known U code to compare? While the whole centres do interchange (if axles swapped) the pumpkins are different.
    Will e-mail a guy I know who has both B and U code LSD's and might be able to clarify what you have.
    Callum
    Perth WA
    They don't, however the standard S Series centre looks like an LSD carrier, it's just 4 pinion open centre.
    Carterton
    [QUOTE=oldcorollas
    [/QUOTE]
    TOSCO listed part number 41301-TE003 for 6.38" LMTD/SLP diff and 41301-TA002 for 6.62" LMTD/SLP diff so both S and D types existed.
    And 5.7", 6.0" and 6.25".
    Does not help you much though.
    Mike
    71 TA22
    My Car
    ok,
    it is definitely not a B 5.7", as i have had one of those and the axles are tiny
    i have compared to a U/X 6" as the axles are a full 1mm bigger, and the dimensions are a bit bigger. the PCD of the crown wheel is also a fewmm bigger than the 6"
    i originally bought hoping it was a 6"....
    the 5.7" is physically smaller as you say, and the axles are smaller again than the 23mm U series.
    It is definitely an LSD, i can see the LSD plates. (but i will check agian tonight )
    It definitely came in a TRD box, and looks consistent with all the other TRD centres i have had in my hands. i have not checked for markings tho. unfortunately, oil on the label has dissolved the ink that said what the model number is
    i have pics, can upload tonight
    hmm. if i can match up any of the outer dimensions, and axle dimesions with one of the series, then it probably is it....
    the bearing toyota part number matches between starlet (too big for starlet) and KE70.....
    Carterton
    By elimination (although wouldnt bet on it) from the TRD catalogue:
    KP LMTD/SLP diffs were specified at 5.7", 6.0" and 6.38".
    KE LMTD/SLP diffs were specified at 6.0", 6.25" and 6.38".
    If axles too big for 6.0" then would probably be 6.38".
    But could be 6.25"
    Mike
    71 TA22
    My Car
    New Zealand
    Depending on year/engine size of Starlet, bearings should be same as KE70. I know for NZ, early (79-82) Starlet were X code and late (83-84) were the U code and exactly the same as KE70. KE70 here never got S code, that was only use in TE71 with 2T-B and in AE70/AE85.
    Callum
    Thanks Mike
    hmm, the 6" axles would free spin inside there unfotunately... and 5.7 is even smaller
    i have not heard of a KP with an S series (6.38) diff but doesn't mean there wasn't any
    what did the 6.25" come in originally?
    thanks Callum ... hmmm
    i know the starlet X (142mm) and the KE10 B (145mm) centres are interchangable, but i am not sure about the KE10 axle splines.
    i know that KE30-55 and some KE70 had U series, same as the later KP6 starlets..
    and aus got S in AE86.. but apart from that.. i don't know much
    if it IS an S series (it is the old style of TRD box), then it might be an ok upgrade for a K powered car or for a cheap LSD for a relatively stock AE86/KE70...
    Carterton
    Some TE2# series Corollas also some RT81 Coronas. No idea which models specifically.
    Mike
    71 TA22
    My Car
    New Zealand
    This may or may not help but got someone to measure up the axles they have stashed away -
    Quote Originally Posted by A top Bloke
    ok these the ones i've managed to find
    Series, diameter, axle spline count, what axle is from, extra notes.
    X ? (will need to pull an axle on the kp60 to find out)
    B 22.3dia x 20 (ke20)
    U 22.0dia x 20 (kp61)
    S ? (i had one but must have sold it)
    T: ....
    24.0dia x 23 spline Early type (ma45, te71, zenki ae86)
    25.1dia x 23 spline Late type (kouki ae86, masterace van front diff)
    26.5dia x 24spline Late type on steroids! (GT4 rear diff torsen, this was a surprise.. i guess i'll be resplining an F series axle after all).
    E 25?dia x 23 (no axles to measure OD, diff has pointier looking spline than the late T series axle)
    F 28.0dia x 27 spline (CR30)
    G 33?dia x 30 spline (hilux) have a head but no axles
    Callum
    T'ville, QLD
    the 24mm x 23spline axle points to d or zenki T, pretty sure there were d series LSD centres but i dont know if they were TRD spec i shall go and measure my zenki lsd centre and confirm that its not T, t series were 6.8 and d were 6.67 i think.....
    2T out 4A in....
    T'ville, QLD
    mmk
    1 = 34mm
    2 = 144mm
    3 = 99mm
    there you have it not a T
    2T out 4A in....
    Thanks for that callum, and please thank the Top Bloke for me too
    must spread rep first
    Thanks Skids... so it's definitely not T series.... even though the axles match
    plot thickens... so pointing to D or S....
    i will hunt around for S axle dimensions today
    Carterton
    Early T type was 6.7" and D type was 6.62". Both ran 24mm x 23spline axles. I swapped my D type LSD for an early T type LSD years ago when original diff wore out.
    Both LSD's were standard Toyota 2 pinion items. TRD produced 4 pinion LSD's for each type (41301-TA002 for D type and 41301-TA003 for early T type).
    Mike
    71 TA22
    My Car
    teq Grease Monkey
    California
    S-series (6.38") axles are the same spline size & count as Zenki AE86 T-series (6.7)
    Andrew
  1. Identifying your diff
    By DQIKST in forum Tech and Conversions
    Last Post: 03-11-2007, 08:51 PM
  2. F series diff centre for drift - Torsen or clutch type?
    By Hen in forum Tech and Conversions
    Last Post: 12-09-2006, 03:12 PM
