I think they are all the same among 16 valve variants, a part number check should clear this up.
not 100 percent sure, but i think 3SG/TE ones fit too
hey all
gotta replace the buckets/lifters in my 4AGZE bigport head. i went into the local toyota dealer earlier today and got a price of 355 bucks for a set.
im going to try and source some aftermarket ones tomorrow....are all the buckets/lifters the same throught out the different 4ag heads. aftermarket people seem to be a bit confused on import engines sometimes
this would make the search much easier. thanks for any advice!
Huw
all bigport 4ag(z)e buckets are the same and the small port would be too but i havent measured both.
to get some buckets try any head reconditioner to see if they have any good 2nd hand ones for the shims just get them from toyota under 5$ each, if the head is alltogether measure for correct clearances to get correct shim.
i havent heard of aftermarket buckets only solids that you have to shave the valve stalk to get the right clearance.
might be worth pricing a set of 1SZ-FE shimless buckets
http://club4ag.com/faq%20and%20tech_...%20Tuning.html
how can you damaged your buckets? ive got a spare set if youre interested. its gen1 3sge thats the same as 4ag i think.
Smallport buckets will also fit. I've used a set on my bigport head. Generally if you have a full set of shims, an engine reconditioner can shave them down to spec provided they're not too munted.
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
