Results 1 to 4 of 4
Thread: 20v ST headers and 16V T-VIS headers
    philippines
    Default 20v ST headers and 16V T-VIS headers
    are there any gains by switching from stock 16v t-vis headers to stock 20v st headers?
    thanks.
    Default Re: 20v ST headers and 16V T-VIS headers
    I cant say that I have tried it but have had a look at the 2 designs.
    It will be much easier to change the oilfilter once you have changed to the 20V headers
    Junior Member Grease Monkey ira11y's Avatar
    apart from the fact that each is designed to suit the flow of that particular head and therefore flow characterstics that will benefit one may not neccesarily be of benefit to the other i think you will also find they have a slightly different bolt pattern.
    Cheers Michael
    Opinions are like assholes, everybodys got one.
    They certinaly do have a different bolt pattern, although people say that you can make them fit with a bit of filing.
    Have a look, in the gasket comparison, the lower gasket is the 20v item, the one wrapped up is for the 16v.
