What do you intend to use the car for? Street, race, daily? What engine are you planning to use?
hi all just wont to know wat would be the easiest way to put 4 spot vented brakes on a ra23
RA28, 1GGTE, Gen 3.
http://www.toymods.net/forums/showthread.php?t=3778
search and you will find:
http://www.toymods.net/forums/showthread.php?t=13803
deepdishfactory
search. search,
oh, and search..............
street use
What sort of power are you after? Will you keep the engine standard? If you are specific about what you intend to do with your car, and maybe what you envisage as a final result when setting it up then maybe some more people can give you feedback about what setups they would recommend.
RA28, 1GGTE, Gen 3.
just a 1jz hope 4 about 250 kw at rear wheels,its just a sunday car
i hope you have a sound understanding of these cars and have done lots of research as to the process of this conversion...it is not one for the faint hearted, and definately not a first conversion to attempt. but hey..good luck to ya.
Easiest way: Corona XT130 struts, peugot disc & hilux caliper. Covered 3 billion times on Toymods.
For a Cerica with a 1J? Go bigger, R33 discs & calipers, with a custom caliper bracket & a bit of machining & redrilling of the disc. I just installed these in myRA23 & it's magical, even with stock pads.
