Results 1 to 8 of 8
Thread: ST162 warning light?!?!
    New South Wales
    Default ST162 warning light?!?!
    hi guys,
    i own a st162 and basically my problem is the engine warning light turns on, on the odd occasion. i dont know why.
    what does the light represent? low oil, high temp, etc?
    when light turns on the temp is about 2/3-1/2 up the scale if that. oil pressure is normal. all fluids are full. there is no knocking (i only run vortex 98) no pinging and i cannot work out why it may come on...
    btw just in case you do not know which light i am talking about it is the light on the right hand side of the headlight 'on' indicating light.
    any help would be greatly appreciated.
    Default Re: ST162 warning light?!?!
    means u gotta check the error codes
    cease striving Conversion King RobST162's Avatar
    http://www.gtfours.co.uk/
    has a fantastic how-to on error codes
    New South Wales
    ok, that link worked great. thanks.
    the error code is for o2 sensor... however i cant locate mine... i cant find it on the exhaust manifold.
    know where it is? 88 st162 with 3sge
    no worries bro
    on a series 2 it's almost directly beneath the firewall on the exhaust pipe - just slightly forward
    yeh u will have to get under it to locate it, its way down the bottom
    yep and its a pain in the arse to get a spanner onto the good news is you can still drive around if thats the only error you're throwing, you'll just get poor fuel economy
    yeah I had to use all my extenders for my socket set and got it from up top via down between the intake manifold and the firewall
    I put the little flangey thing upside down on-reinstall and it was way easy then
  1. you can light up your speedo with LEDS
    By puzzle man in forum Tech and Conversions
    Last Post: 21-03-2006, 11:34 AM
  2. Alternator Warning Light Wiring
    Last Post: 04-01-2006, 10:32 PM
