Results 1 to 9 of 9
Thread: 4afe crankshaft bolts
    Default 4afe crankshaft bolts
    I have spent days trying to find an answer to this question.
    I am about to put a ae101r into service as a family hack and want to make some modifications to it. It is auto and I plan to put a 7afe into it. I know that 4age has 8 flywheel bolts and that 7afe has 6 bolts but what does a 4afe have?
    I plan to keep the auto and the ECU that are 4afe ones, has anyone done this?
    Please don't suggest that I convert it to a 4age is anything as P platers drive it so any mods need to be invisible.. I plan to port the 7afe head to help breathing.
    BTW does anyone have a cheap 7afe for sale in NSW?
    Aug 2006
    success 6164
    Default Re: 4afe crankshaft bolts
    pretty sure its 6 bolts.
    http://www.ae82ownersclub.com/forum.php
    powered by 4agze ae82 goodness.
    Yep 6 bolts, just the same as a 4A-C.
    www.billzilla.org
    Toymods founding member #3
    Default thanks Bill
    Bill,
    do you remember Luke Sheerman from years ago (when Toymods started)? I did the work on his sprinter and he has just been to Uluru in the Bugeye sprite he bought off me a few years ago (its on youtube). Thanks for your response, Do you know how well you can make the 7afe heads flow?
    Barry
    perth
    i wouldnt touch the engine just stick it in and be done with it, you wont feel any differance by porting it unless its a major cc'd port job with cams and bigger valves.
    Default Re: thanks Bill
    Quote Originally Posted by sprite059
    Bill,
    Barry
    Yeah I remember Luke well - He's member #1, Mos is #2, and I'm #3.
    If you get the right 7AFE head it'll flow better than any G head. They don't need a huge amount of work to do so either.
    www.billzilla.org
    Quote Originally Posted by Billzilla
    I took Mos's IS200 for a drive not too long ago up here in Dubbo, I have just about finished converting my eldest son's MA70 into a 1UZ manual.
    BTW where do I source the "right 7AFE head" Bill?
    I actually can't remember if I was a passenger or I drove it, I must be getting too old!
    It's the Japanese-produced non-TVIS head. They have a single inlet port. The TVIS ones have two ports per cylinder. That single port angles down into the head steeply, not nearly horizontal like the more common crappy 4AFE heads mostly do.
    www.billzilla.org
  1. Negative Rear Camber bolts for MA61/MZ10/MX73 !!
    By bbaacchhyy in forum Tech and Conversions
    Last Post: 03-08-2014, 09:12 PM
  2. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  3. 5-ME crankshaft pulley bolt
    By GasedT18 in forum Tech and Conversions
    Last Post: 31-12-2006, 12:21 PM
